Sponsored by: CARiD
I Need Some Clarification on 3rd Member Interchangability
Old Apr 3, 2008 | 06:31 PM
chvyhs's Avatar
I read around and this is the best information I could find on swapping out 3rd members.
http://home.4x4wire.com/erik/diffs/#front
I'm still not sure what is interchangable. I have axles out of a 1981 Toyota Long Bed. It was a 4 cylinder truck and I'm sure I have 4 cylinder 3rds with 4.10's. I want to go with either 4.88's or 5.29's. I already have a full spool for the rear and a Lock Right for the front. I also have 30 spline Longfields in the front. What I'm trying to figure out is what are my options for swapping out 3rd's?
1. Are V6 3rd's a good option?
2. Are High Pinion 3rd's a good option?
3. What would be my best choice for my FToy?
Thanks
Old Apr 3, 2008 | 08:08 PM
Yoda's Avatar
you can swap 3rds up to 95 with little/no problem
V6 are stronger
hi pinion only in front (good choice if you are lifting)
There is also the e-locker option, but you have to modify the housing to fit
Old Apr 4, 2008 | 10:08 AM
chvyhs's Avatar
So I can use the same Lock Right and Spool in these 3rd's? (With the exception of the e-locker 3rd.)
Old Apr 4, 2008 | 12:57 PM
Yoda's Avatar
I don't know about the spool or lockrite being interchangable between a V6 or 4 cyl diff. I just know the whole diff will drop in.
Old Apr 4, 2008 | 01:01 PM
AxleIke's Avatar
spool yes,
lockright, check again. I was under the impression that you CANNOT, because the 4cyl is a 2 pinion, and the V6 is a 4. I know you cannot interchange an aussie locker. Aussies and Lockrights operate in the same manner, so hard to say.
Old Apr 4, 2008 | 01:14 PM
TOYOTA 1's Avatar
Originally Posted by AxleIke
spool yes,
hey ike, was just wondering your personal opinion on a aussie type locker?
Old Apr 5, 2008 | 09:13 PM
chvyhs's Avatar
OK,
I'm sticking with the 4 cyclinder 3rd's. So I can continue to use my spool and Lock Right. I'm just going to put 4.88's on what I have.
Thanks for all the info.
Old Apr 5, 2008 | 10:11 PM
AxleIke's Avatar
Dislike them A LOT.
But, I understand people on a budget, so whatever floats the boat I guess.
Personally I don't recommend anything except ARB's and Elockers. Most people don't want to wait that long, so they go cheap.
runnermedic
13
Sep 21, 2015 05:20 PM
icentropy
Sep 10, 2015 05:03 AM
