I Need Some Clarification on 3rd Member Interchangability
I read around and this is the best information I could find on swapping out 3rd members.
http://home.4x4wire.com/erik/diffs/#front
I'm still not sure what is interchangable. I have axles out of a 1981 Toyota Long Bed. It was a 4 cylinder truck and I'm sure I have 4 cylinder 3rds with 4.10's. I want to go with either 4.88's or 5.29's. I already have a full spool for the rear and a Lock Right for the front. I also have 30 spline Longfields in the front. What I'm trying to figure out is what are my options for swapping out 3rd's?
1. Are V6 3rd's a good option?
2. Are High Pinion 3rd's a good option?
3. What would be my best choice for my FToy?
Thanks
Thanks
you can swap 3rds up to 95 with little/no problem
V6 are stronger
hi pinion only in front (good choice if you are lifting)
There is also the e-locker option, but you have to modify the housing to fit
V6 are stronger
spool yes,
lockright, check again. I was under the impression that you CANNOT, because the 4cyl is a 2 pinion, and the V6 is a 4. I know you cannot interchange an aussie locker. Aussies and Lockrights operate in the same manner, so hard to say.
hey ike, was just wondering your personal opinion on a aussie type locker?
But, I understand people on a budget, so whatever floats the boat I guess.
Personally I don't recommend anything except ARB's and Elockers. Most people don't want to wait that long, so they go cheap.
runnermedic
13
Sep 21, 2015 05:20 PM
icentropy
Sep 10, 2015 05:03 AM
