Sponsored by: CARiD
A few`91 pickup questions
Old May 5, 2008 | 12:26 AM
bigisletoyota's Avatar
whats up everyone. I have a '91 3.slow pickup
i have two questions.
1.) I cut off the tail pipe (after muffler) on my toyota pickup exhaust for a little more "noise" and i guess more flow.
will this help or hurt my gas mileage??
2.) anyone have any information on the ISR MOD that i have been hearing so much about???
Old May 5, 2008 | 05:59 AM
elripster's Avatar
ISR: http://www.ultimateyota.com/index.ph...=3819.msg37152
It's unlikely your MPG will change much if you cut the pipe. You might find you have more torque at higher RPM's. You can always get a sleeve from your auto parts store and reattach the pipe if you don't like it.
Frank
Old May 5, 2008 | 07:32 AM
aviator's Avatar
Here's a YotaTech link for the ISR mod: https://www.yotatech.com/forums/f130...4runner-75167/
Cutting the pipe will really only make your truck noisier and also increase the under-body temperatures which may lead to a fire or Carbon Monoxide poisoning. You'd be better off putting a larger diameter exhaust system with a "free-flow" CAT on your truck to get better performance.
Old May 5, 2008 | 11:38 AM
dirtoyboy's Avatar
cutting off the exhaust tip wont do a danged thing except collect gasses under the bed of the truck instead of exiting the side like normal. I cut mine even with the leaf springs exiting out the side..
I wouldnt recommend cutting up your airbox for the "ISR" mod or whatever either.
bigjstang
Jun 2, 2025 03:56 PM
kazuya2416
Apr 5, 2024 02:17 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
Cplmike
Jul 8, 2015 08:47 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
