Sponsored by: CARiD
truck only turns over half the time
Old May 3, 2008 | 03:45 PM
88Yota4runner's Avatar
ok, soo up until a week ago my truck would start up and run fine, its a 1988 22re 4runner i used to have a v6 runner and at one point in time i had to change out the 80 amp black fuse under the hood, but i never realy found out what exactly that controls, because now i just found that same fuse in my current 4runner completely smashed off of where the other fuses are, kinda like someone took a hammer and hit the fuse and the plastic casing it sits in broke off of the rest, but anyways for the last 4 days now its only been starting up everyother day ???? what the heck could cause that, any help would be awesome and if anyone could tell me what exactly that black fuse does would be aweomse thanxs for your help.
Old May 3, 2008 | 06:13 PM
its been like 2 hours guys come on....
Old May 7, 2008 | 05:54 PM
yoder519's Avatar
ye amine was doing that and everyone on here told me the contacts on my starter are workn.
i dnt know if its the deal with you though
Old May 7, 2008 | 06:14 PM
texcat101's Avatar
Mine was doing the same thing until i put a 12v 20amp relay in that is activated by the original starter circuit but delivers power direct from the battery to the spade terminal on the starter. the original starter circuit had for some reason lost it's ability to pass thru enough juice to fire the starter. but still had plenty to fire a smaller relay. oh well, it work's not a problem since.
Old May 7, 2008 | 06:23 PM
4Crawler's Avatar
Quick check you can do:
http://www.4crawler.com/4x4/CheapTri...shtml#EasyTest
And easy enough to replace the solenoid contacts, that is the common problem.
Old May 7, 2008 | 08:17 PM
rowdy235's Avatar
If it is the contacts they are super easy to replace. I don't feel good doing any more than changing my oil yet I accomplished it in less than 2 hours with only basic tools.
bigblue82
10
Jul 6, 2015 08:27 AM
Butch35
Jun 25, 2015 07:47 PM
shadowbirdie
Jun 24, 2015 03:54 PM
Eagle564
Jun 23, 2015 11:29 PM
