Sponsored by: CARiD
Take a look at this pic! I need some help
Old May 21, 2008 | 04:29 PM
94toy4x4fever's Avatar
Look at the pic Im talking about this thing that is circled in Blue! Its called a pair valve. There is a pipe that is conected to the exhaust manifold that goes around the back side of the head then in to this PAIR Valve. Then were does it go from there? Into the air intake then to the EGR? I have been having some EGR problems and cant figure it out! And does exhaust gas frow from the exhaust manifols thew the pipe then into the pair valve then into the EGR?
Old May 21, 2008 | 04:32 PM
dropzone's Avatar
Fossilized
all I see is a little red 'x'. looks like your attachment did not go through. consider uploading your pictures to a free service like photobucket.com and than copy and past the [IMG] code to your post.
Old May 21, 2008 | 04:34 PM
[IMG][/IMG]
Old May 21, 2008 | 05:35 PM
HAVOC's Avatar
Here is a diagram, but it's for California emissions. Let me know if you need it for Federal.
That "pair" valve is an Air Suction reed valve.
File Type: pdf
Old May 22, 2008 | 05:36 PM
sorry guys i got the pic up! Take a look! Need help
Old May 22, 2008 | 06:20 PM
HAVOC's Avatar
Did you check out the .pdf file I attached in my last post? It has a diagram that will show you how the vacuum lines are routed.
Old May 22, 2008 | 07:44 PM
I know how all the vaccum lines go! I was just wanting to know how the Pair valve workes! Thats the inside the blue
Old May 23, 2008 | 03:03 AM
HAVOC's Avatar
Here is a desription on the system and inspection.
http://personal.utulsa.edu/~nathan-b...20pulsedse.pdf
Old May 26, 2008 | 04:21 PM
HAVOC's Avatar
Federal vacuum diagram:
File Type: pdf
4.34runner88
Feb 7, 2016 02:24 AM
Obmi
Nov 24, 2015 11:37 AM
bobjohnson2121
Sep 17, 2015 08:07 AM
HiLuxer
Sep 9, 2015 02:43 PM
