View Full Version : Newbie Tech Section
- 94 4runner questions and opinions wanted
- Will the metal plate off an 89 shift boot fit an 87?
- Toyota Truck 1989 won't start
- 93 3VZE Run issues, no CEL, lots of troubleshooting
- Replaced Fuel Pump Truck Wont Start
- 96 4Runner 4x4 not engaging
- 2" body lift + 3" suspension lift for 35s
- Valve cover baffle ?
- What size starter do I need
- 92 V6 3VZE Coolant in Exhaust
- 1983 4x4 replacement fuel tank
- New 1982
- need help with 89 Pickup shocks with 4.5" lift
- O2 sensor
- L series Detent Spring and Compatibility
- New to the T4R scene from Hawaii!
- new 22r and new carb rough idle when cold help!!!
- Bolt pattern
- Fuel pump preference?
- Rear third member interchange
- Please help coolant in oil
- Need help identifying leaf spring lift
- 22r swap 7mgte
- 1985 ext cab sr5
- How to Support Transmission?
- 22r Operating temperature idle issue
- 1983 4x4 Truck Brake Caliper Question
- 77 shifter bushing
- Shackle Lift and Pinion Angle
- 85 22r
- Front end compatibility
- 22re high temps at stop
- Thoughts on valuation
- Reading CE 3.0 vz
- 84 head lights
- Help with Lift Types and Ball Joint Angles
- Swapping parts on rear axles
- sealer for carburetor
- Pitman Arm Position
- Double Trouble 86 Yotas
- No dash light or tail lights.
- Torsion bar/cambolt
- In need of some advice!
- 93 4runner bad front vibration(driveshaft?)
- Fj62 Axles vs Mini truck
- What is this part?
- How to check for codes
- Looking for info on 1983 Celica EFI
- No air running through vents on 95.5 Taco
- 3rd Gen Decals
- Reversing a mystery lift
- R151 5th gear up grade from a R452ybody
- Sea foam spray...
- Exterior door handles compatibility
- Tacoma 3.4 suddenly starts missing and throwing codes now doesn't run!
- EFI power no power to Fuel Injector pigtails 95 3.0
- Code 6 help maybe
- Help Needed: College student homesick for truck
- ECM Help
- Frame swap question for sas
- Looking at a 4runner with 5.71s - too much?
- Knock Sensor New and old HELP
- 81 transmission swap questions
- to stating v6 3.0 1995
- No Drive from Park in 2002 Tacoma
- Re:1994 Toyota pickup manual 4wd 4 cyl
- Need Toyota life advice.
- Help 3.0 1995 v6 not starting
- Vent removal
- Overheating problem
- Looking for which forum to post in
- Difficulty setting timing on 20r
- Turn Signal Assembly, Leaf Springs, etc.
- Higher than normal idle questions
- HELP!!!! step by step head gasket replacement
- long travel steering rod to spindle question?
- New rebuild runs rough low idle backfire.
- 1996 to a 94 front grill setup swap
- O2 sensor nuts??
- abnormally high compression
- need info if timing belt Tension sprug or moved
- 85+ 22r in 82 pickup
- 3vze idle surge
- Diagnosing No Start w/ apparent spark, compression, and fuel
- 22re won't idle anymore
- 3vze knock sensor ecu?
- #2 idler pulley
- 90 4runner spare tire swap- not what you think
- 305 swap 2nd gen
- 2nd gen 4runner Frame Rust
- Fuel injector ohms
- won't suck gas
- need some advice
- The rear head gasket is leaking... Common?
- Issue with Head Gaskets? Oil/Gas left in too long?
- 99 taco fuel pump testing??
- Can the Air Filter Sensor Cause My 4runner to no start?
- Rear main seal leak?
- 90 4 Runner wrecked now upgrading
- Novice 77 Toyota Hilux owner
- 20r Manual Fuel Pump
- allpro lift kit install help?
- 98 4 runner shak
- Quick 3.0 2nd gen ISR question
- newb who might have purchased a rustmonster
- Transmission issues after replacing rear axle seal
- what is this?
- O2 sensor wiring harness - where's it go?!
- Broken transfer case
- Electrical Problem
- transmission dipstick - accurate reading 3rd gen 4runner
- Part identification, and other questions
- 1985 w/35"s Brake pedal hard w/minimal stopping power AFTER...
- The surging! I need advice...
- 1985 22R-EC Electronically Controlled Transmission (ECT) indicator wiring diagram
- Not running out of money just sense
- 1988 4runner on 1985 frame, swerving during hard breaking
- '84 timing chain help, interference engine
- Bell housing bolt locations
- Need some help here
- Engine stand
- 79 20r egr valve
- 91 will run fine then all of a sudden not worth a hoot?
- FJ 80 Springs
- 93 4X2 DLX Auto Pickup
- 1991 4 cylinders camparison
- Dead cylinder fuel smoke what's my problem??
- Electrical help
- 85 4runner random miss, CEL flashes during decel.
- Tire PSI
- Rusted out rear top shock mount.
- Engine sputter / bucking
- EGR missing gasket?
- Death dually fix ? Tiny house build 1984 toyota to 1995 4 runner rear end swap help
- Front brake pads
- starting problem. starter relay click
- First time doing a timing belt on a 06 V8 Tundra questions
- '89 22RE pickup suspension
- 99 4Runner Issue
- replaced ignition tumbler with 2 toggle switch and push button start
- dreaded code 52
- Gear oil
- 3.4L cam cap arrow direction?
- weber 32/36
- noob ? 96-2002
- 2008 Tacoma transfer case
- 2l-te ?
- 1991 Pickup 22RE Auto - Sitting for a while - No Start
- 2012 V8 Timing Belt
- What size lift do I have?
- Driveshaft is spitting out a bunch of sludge
- Coolant in the oil.
- squealing alternator belt
- Very rough idle
- Electrical Issues on my 86 22r HELP!
- 22RE head is stuck
- clutch start bypass button?
- Troubleshooting '86 Pickup That Wont Start (No Click)
- 94 22re runs but dies after a few seconds... Help please!
- 93 Toyota Pickup - RC, 22RE - Diagnosing Start Issue and Distributor Cap
- 83 carb/aircleaner
- No start issue
- Differential Noise
- 98 Tacoma Losing Power/Starting Issues
- acceleration/deccel. sputtering/hesitation
- 3rd Gen Pickup Manual Steering
- Sheared Torsion Bolt Head- Unsafe?
- Exhaust manifold bolt pattern
- Rear Main Seal Replacement/ AC Clutch Question
- Gas coming from exhaust
- 83 22r compression issues
- 88 22re won't start
- Front Solid Axle Bearing Replacment
- Wanting to rebuild/clean my carb
- Coolant flush questions
- 94 truck exhaust manifold question
- 22re knock and buring oil
- Timing all over the place
- 1986 yota pickup 4wd fuel pump
- Introducing myself
- First time crawler trying to decide
- 22re Noob Timing Chain Job
- Any members near Marietta, Oh?
- Manual Gearbox 88 pickup
- 22re timing adjustment made it run worse?
- Brakeline bracket
- 20r vs 22r dizzy
- Name this air system hose?
- Bleeding master cylinder with finger
- 95 Toyota t100 cracked fire wall
- Vent and Return lines
- 3.0 motor
- 2000 4runner 3rz 5 speed 4wd
- Oil Pressure Sender Repair - 93 Pickup 22RE
- Out of ideas! Please help!?
- Rav 4 seat cover suggestions
- Low MPG on rebuilt 22RE caused by custom exhaust?
- Brake line size? 2nd gen 4runner
- Idler arm
- '95 4Runner. Do I need shocks for a lifted application?
- A/C clutch will not engage at idle
- 2015 Tundra cruise disengages/loses forward speed
- 90 truck fender cut and fender flare question.
- Question on engine removal
- Alternate source for genuine Weber kits?
- '98 4runner - no fluid to rear leaving ABS pump after changing brake fluid
- 85 4 runner
- What is this part? Help!
- 22 RE Mystery problem
- Cruise control actuator
- flat towing or towing 4 down
- 22re idles but dies when driving
- 22re rebuild
- 85 22re 4x4 extcab belt not pulling pulley? also is this leak bad?
- Power steering Noise
- air ride suspension?
- Balancer/Seal on 22RE Question, HELP
- 1985 4runner
- Will nothing fix my 22re misfire?
- Some brake system 101 please?
- 94 22're misfire & code 71
- No fire to plugs
- 992 4runner, hard to start when cold but not when hot
- Yotasite batting 100, a/c dash wire questions
- Getting 285 70r 17 tires
- Help with transfer case shifter install.
- Battery dies while running ac??
- Thermostat Housing Longevity?
- Needing help purchasing a 34 tooth speedometer gear for my 96 Tacoma with 4:10 gears
- zuk mod ?'s for 1984 bandit (2wd p/u)
- 1st Gen Looking for OEM Running Boards
- Is it safe to run sae40 for 1000 miles?
- 1995 1/2 pickup
- 94 4runner show-off
- Help ??: 3.0 start issues
- 4bt swap questions
- 1991 SR5 Pickup Smokes over 3K RPM
- 86 22re cranks but wont start
- Tires I need 16.5" rims
- Not sure what I have - IFS or Solid Axle
- 1990 truck 4x4 ifs lift question.
- 1998 4runner hatch wiring question (rear window, wipers don't work!)
- Wiring harnness diagram.
- 1992 Pickup 4wd Xtended Cab Lift
- Fuel Pump not getting power
- Speedometer problems
- Axle seal replacement gone wrong
- 96 T100 Auto Transmission Fluid
- Tacoma knock sensor problem
- Shock torque specs 1991 SR5
