Sponsored by: CARiD
squealing alternator belt
Old Jul 17, 2016 | 08:45 PM
taraf's Avatar
A couple of weeks ago I had to change out my water pump (83 22R pickup).
Since then, the belt has been squealing when accelerating at the low end. The belt is loose. But I don't know how it got that way since I did not loosen the alteranator mount when doing the water pump job.
I tried to adjust the alternator today - loosened the mount screw - alternator wouldn't budge. I used a wood drift on the bolt 'ledges', but the thing seems frozen in place. Am I missing something?
thanks!
Old Jul 17, 2016 | 11:52 PM
wyoming9's Avatar
Both bolts in the alternator bracket need to be loosened
The upper one in the adjustment slot and the lower one .
How did you get the belt off if you did not loosen it ??
Old Jul 18, 2016 | 07:24 AM
taraf's Avatar
ahhh. That would explain it...d'oh
guess it must have been pretty loose already.
the whole truck is a mess. I'm saving it, wire by wire, hose by hose...
Old Jul 18, 2016 | 01:03 PM
highonpottery's Avatar
do the above to tighten. belt dressing also does wonders when belts make noise, but doesn't help when it's not adjusted properly.
ladybugRC
Feb 18, 2016 04:50 AM
lowprofile98
11
Nov 8, 2014 12:29 PM
Desertrat
Sep 14, 2002 08:09 PM
BTOWN4RUNNER
18
Aug 10, 2002 01:26 PM
C2damuthafuqinLO
Jul 29, 2002 01:37 PM
