Sponsored by: CARiD
Differential Noise
Old Jul 3, 2016 | 06:23 AM
apurso's Avatar
Differential Noise
Hello,
I have a noise which appears to be coming from my rear differential on my 1995 toyota 4runner 3VZ 6 cylinder.
I cannot hear it at high speeds but when i'm slowly cruising through a parking lot or back road between 5 or 10 mph it sounds like a rubbing noise coming from the rear as the tires spin. I checked underneath but see no obvious issues and no leaks.
Thank you for any replies
Old Jul 3, 2016 | 06:27 AM
apurso's Avatar
BTW i did grease all the joints / yokes & spiders
Old Jul 3, 2016 | 08:15 AM
ZUK's Avatar
ZUK
Could be a bad outer pinion bearing....or loose pinion nut. Leaking any gear oil from the flange?
Old Jul 3, 2016 | 12:53 PM
apurso's Avatar
Sorry after further trouble shooting i had someone in the passenger seat with their head out the window listening to the noise that i thought was coming from the rear end. Turns out the noise is coming from the passenger side wheel brake assembly in which i just had all new rotors / calipers / and ceramic pads put on both sides. While i got you though any idea what the thumping noise could be after all those parts were recently replaced 10 days ago from a reputable garage? Would like to go in there when i take it back & maybe help them diagnose the issue...warped rotor perhaps (new) loose pads? caliper not operating properly? Wheel bearings? I don't know much about disc brakes...anymore info would be helpful...
Thank you
Old Jul 3, 2016 | 09:48 PM
ZUK's Avatar
ZUK
could be anything.....just jack the tire off the ground and spin it by hand and observe. That's the only way.
Old Jul 4, 2016 | 03:52 AM
apurso's Avatar
I jacked it up and spun the wheel by hand and can hear it faintly but i'm guessing it's faint because of all the weight taken off. Thanks for the tip
SilentBounty
Mar 22, 2016 10:29 AM
potbob
Feb 18, 2016 02:58 PM
86 87 4Runners
Feb 15, 2016 03:47 AM
Oskr MorĂ¡n
Feb 11, 2016 04:46 PM
LOUIS
Aug 21, 2002 08:33 AM
