Sponsored by: CARiD
#2 idler pulley
Old Sep 23, 2016 | 09:50 AM
cryptkeeper's Avatar
#2 idler pulley
after putting in the knock sensor, and Manifold back on, when I went to put the #2 idler pulley back in the timing belt was tighter then when I took it out,, is that a problem ? also what is the tork on the 4 bolts that hold that on ? I don't now if the belt moved why'll doing the Knock Sensor, any input ?
Old Sep 24, 2016 | 06:35 AM
Hi I guess no one has any input on this ?
Old Sep 25, 2016 | 03:00 PM
Punchy's Avatar
What size bolts and markings?
Has the tensioner sprung?
all corners of the intake manifold even or un-even?
New timing belt?
Don't worry about the belt slip until your ready to align and tighten it down.
If you need the know where the marks go, here.
http://htftp.offroadsz.com/marinhake...67timingbe.pdf
Old Sep 25, 2016 | 04:43 PM
I don't know if the tensioner sprung or not and if it did what does that mean ? Corners of intake manifold is even , Timing belt looks good . the bolts are the ones that were in it , they look original . the belt came up a little and I just put it back in the groves and when I went to put in the #2 idle pulley it was tight so I had to put a little push on it to get the bolts started they tightened up.
cbr600rx7
Sep 9, 2018 01:34 PM
Jason4X4
Jan 19, 2018 09:06 PM
Iceman4193
Sep 10, 2016 10:14 AM
808yotapma
Sep 1, 2016 04:51 PM
redghost.308
Aug 29, 2016 09:47 AM
