Sponsored by: CARiD
Higher than normal idle questions
Old Oct 1, 2016 | 11:57 AM
Montana22re's Avatar
Hello there, I am new this site and Toyota's. I have 90 4runner with the 22re and my question and concern is my engine will idle warm at 1200 to 1400 rpm.... I think that's high. And the adjustment screw is turned down all the way. So I can only increase the idle as far as adjustments go. And I did remove the dashpot for the time being... Any help or suggestions would be helpful. Thanks all.
Old Oct 1, 2016 | 02:34 PM
wyoming9's Avatar
In rare cases I have seen the throttle body shaft worn so hard it allows a airleak
Has the throttle body itself ever been cleaned ??
Lube the throttle body linkage??
I tend to spray mine every oil change if not more often
Checked in the cab that nothing is binding or broken where the throttle cable goes through the firewall
Causing the throttle pedal to hang up
How does it idle with the throttle linkage disconnected ??
Any Vacuum leaks ?? Vacuum hoses on wrong could cause added air
Air intake system is tight no cracks or leaks.
damnthemansam
Oct 3, 2016 05:27 PM
George Golightly
Oct 1, 2016 11:56 AM
Brett39532
Sep 29, 2016 06:12 PM
93yoterexploder
Sep 23, 2016 12:44 PM
Claytonkitner
Engine Swaps
Sep 3, 2016 09:10 AM
