View Full Version : Newbie Tech Section
- Cv axle splines
- What could cause 22re to sputter when cold
- Poor gas milage
- 1996 4Runner Accessory Belt replacement
- aftermarket exhaust
- Problems with Toyotech lift
- dual exhaust?
- leaky cv axel
- need help for ideas!!
- driving in water
- too late for "service campaigns"?
- 3vze engine troubles
- Cel p0440
- Brake Caliper/Pad Assembly
- Help me replace this water bypass part on my 95 3.0
- New Head for Old 20R
- attaching hardware
- 20014runner tranny help
- 22r carburetor issue -need lil help
- 85 4Runner Engine Noise
- sas conversion questions
- Question about idler and pitman arms?
- PCV Valve location
- Cheap HP gains...
- Need help with antenna.
- Crankshaft pulley installation
- mud proofing
- lift
- 2002 4runner limited
- 93 Pickup with 22RE
- Engine Swap
- need rim help
- Odd noise under heavy acceleration.
- Newbie!
- rehealing the "ol reliable'
- gear chatter problem
- newbie t100?
- 2wd 4runner project insperation (HELP)
- what is the differance between a 4cyl front axle and the 6cyl?
- 1998 toyota 4runner 2wd SAS questions
- Tailgate swap
- Replace head w/o Timing cover removal
- can just the shocks in the front coils be replaced?
- Steering Issues
- 2004 4runner shocks and coil over question
- Need help replacing worn stock exhaust
- start but won't run
- 22RE Valve Adjustment - What should it feel like?
- 3rd gen to '00 taco front clip
- Help me choose a suspension lift
- 87 runner sas
- Spark plugs not all the same color??
- Your Opinion Wanted: What else to replace while I've got the Valve Covers Off?
- Advice on simplest way to take off a body lift.....yes, remove it.
- New truck, few questions
- Compression test numbers? 22re
- Tire help
- Dual transfer cases?
- need new front shocks for my 86'
- cant get 22r started
- Someone Please HELP! I Need Good 3.0 motor pics
- New to modification world.
- Replacing bearings/hub won't slide back on
- Replaced pitman & idler arm, now no speedo?
- 2000 4runner Tranny slipping....
- 89 FJ62 Oil Pressure Issue
- Brake Line Flare: Double or Bubble?
- INtro Hello and minor/serious issues?
- Removing brake hose - rusted on, wrench only rounding bolt
- gauges
- sas s-10 leaf springs
- get me started
- BJ Spacers And UCA
- 99 4cyl CEL
- How do I tell if I have a "1/2 Ton" on "1 ton" truck?
- 2wd to 4wd swap.
- 8.8 semi-floater under Runner!
- what kind of tranny do i have
- April Is National Car Care Month (USA)
- Rear 4.88 Third
- Gas leaking out the exhaust!
- Tapping felt through thermostat cover
- 92 Camry won't start
- finally the chirping is gone!!!!!!!!!
- 87 left tire/suspension problem
- v6 vac. line help!!!
- tranny swap
- Noise coming from rear end?
- What coax cable do i need for this:????
- coolant temp sensor change
- help! my 4wd doesnt work!
- How hard to change front passenger side axle???
- 2001 4Runner headlamps always on
- 89 P/U 4x4 v6 5s just bought got questions
- Figuring out a 5 Speed swap
- Needing advice on leaking diff fluids
- 2000 4Runner Keyless Entry Question...HELP!
- Nitro gas shocks cheap?
- another one of those gears threads... lol
- How do I remove the front brake calipers?
- 22R or 22RE?
- Buying a Tacoma TRD, questions
- Need Your Opinions and Help!
- Parking break bell crank stuck
- How can you tell if you have a locker?
- stripped rear differential oil fill plug!!!!!
- 88 4runner with 37s
- Larger tires...
- toyota 1988 pickup bearing change
- No engine power???????
- Gears ?????
- Bed fitment question.
- 00 Tacoma motor into a 93 pickup?
- Whats The Best SAS
- Show Your Custom Bumpers
- LC 60 Axle strength?
- Down hill towing with horse trailer
- ????91 pickup suspension question????
- 85 pickup with 22re won't start
- BJ Spacers
- Wilson or Firestik????
- NEWB -Questions regarding lift kits
- 7.5" Ifs carrier bearing replacment
- what a decent pair of shocks are?
- No start? cracked the fuel line to check for fuel now it works?
- New to my 88 I NEED PARTS...WHERE
- locker and gears questions
- 88 headlights on an 86???
- new to yotatech with questions for mods 99 runner
- Please Help 22RE Question
- Oil Filter Relocation Kit
- I'm new to 4WD - can I get some pointers?
- Lockers
- dash lights out on 4th gen
- question about myserious rocking..
- cricket lick chirping noise
- quick SAS question -- good price?
- Im looking for Solid VS Independent axle pics
- Changing from a green to a bright white color???
- swerving to left
- TRD suspension
- Timing problem
- OIL pressure problem
- noobie here
- Ball joint spacer question
- 2009 Tacoma ... rust after 2 months
- Where is my fuel filter located? 1990 Toyota
- How do I start a engine thats been sitting years?
- 87 4runner hic-up while driving sometimes?
- clunking sound while slow driving??
- Towing capacity?
- my gear ratios
- custom ideas
- My 4runner is Canadian. Intrument panel ?
- good machine shop needed in nj
- newbie-94 pickup questions/help
- Is my 4runner a '89 or a '90?
- starter question 22 re
- Newbie terminology thread?
- Failed smog and I am LOST to whats wrong
- Should I sell my 3.0L?
- dana help needed!!!!!
- 20R Valves... Adjustment
- Hesitation at 30mph
- Heater Controls and windshield
- Need help with sas
- Help with 83 longbed pickup
- #1 solenoid sticking or not working
- starting on a hill in 4-LO
- Rear License Plate Lights - Rusted
- 94 pickup 22re new motor power loss low acceleration
- CEL revealed TPS problem. So exactly how hard is this gonna be to fix???
- sputtering, hesitation, and backfiring durring acceleration
- Where to wheel around Santa Rosa or Northbay CA??
- 3l issues????
- Solid Front Axle Questions
- Manual Transmission 3 inch Body lift
- good online stores to buy parts
- 4Runner will only start using autostart on my keyless entry
- just confirming an answer i found... 93 4WD PU
- 94 pickup driving issues
- Removing Muffler
- Quick timing question
- 85 Runner 350 swap ??
- Removing rear seat backs
- 35 inch tires with ifs and 4.56s
- transmission swap
- Help creating an offroading 4runner!
- NEWBIE..Spindle nut Question on 88 Pickup????
- knock in engine
- 83 22r in a baja beetle
- Clutch Problems
- Throttle Body Spacers???
- 2.5 front lift for a 96 Runner
- 86 toyota pick up
- Can a g52 replace my l 45
- FORGED VS. hyperutectic pistons
- New to Forum, 1996 3rd Gen 4Runner Questions
- Firing on only 5 cylinders.
- exhaust manifold
- 84' pickup thermostat location
- So it is not a rear main seal leak... CRAP!!!
- wheels spacers???
- Rover guy w/question...
- 3vze EFI Problem
- Truck broken into last night!!!! New key-hole assembly or repair??
- Misfire after engine wash!!!
- solenoid / starter help!?
- wiring diagram
- bilstein 5100's help!!!!
- 02 4Runner Q's
- offroading/mudding spots in PA
- 92 4runner has trouble starting...
- intermitint miss
- No parking lights or dash light PLEASE HELP
- No Brakes!!
- 82 transmission
- 5th gear bucking 22r
- Making Daily Driver/Desert truck
- help 3VZ-E under intake manifold oil?
- Question about running odd tires
- Header only on 22re - need to adjust AFM?
- New block is differnet- help
- 125w amp --> 80w speakers?
- passenger rear brake harline, where can i buy one?
- Problems with p/steering
- '91 V6 4x4 lost OD/High Gear AT
- 86 4runner build
- overheating 3vze
- Rear-end Question
- Removing starter on 89 truck w/ 5spd I4
- Which is more stable body lift or suspension
- SEAFOAM question.
- 91 4runner instrument cluster
- torsion bar replacement minimum setting?
- Last question.
- now a 22re with issues
- Belt or Tensioner?
- strange grinding noise after hard hit
- replaced alternator wont stay started 95 4runner
- Newbie looking into a 4Runner, transmission and questions.
- How do I change the differential fluid?
- front axle swap issues
- What's the difference?
- identify this noise!
- Newb Help. v6 and 4cyl spider gears?
- Build
- Brake Pad Installation Question Anti Squeal Shim Install or leave out?
- Ridiculous idea
- 92 4Runner not going into 4WD
