Sponsored by: CARiD
SEAFOAM question.
Old Mar 17, 2009 | 05:33 PM
85 SR5 Man's Avatar
SEAFOAM question.
these directions are from the Seafoam website:
"With engine warm, slowly pour 1/3 to 1/2 pint through carburetor or throttle body throat. (If vehicle is port injected slowly pour SEA FOAM through direct manifold vacuum line that will feed all cylinders, possible sources are P.C.V. valve or brake booster line.) This will pull SEA FOAM down on top of the pistons and to the back of the intake valves to dissolve carbon."
Does this mean pull the PCV and it pour down where it sits in the rocker arm cover?
thanks for your responses
Old Mar 17, 2009 | 05:44 PM
bigt's Avatar
i did it in the break booster just remove hose and pour it down.. put the other half in the gas tank... and if youput it in oil then make sure you change it!
Old Mar 17, 2009 | 05:46 PM
85 SR5 Man's Avatar
change oil on regular cycle or put in the oil just before next change
Old Mar 17, 2009 | 05:55 PM
waskillywabbit's Avatar
Welcome to Yotatech.
Several things will make YT more enjoyable as there is a wealth of knowledge here.
You can search using our search feature or using and specifically searching Yotatech.
Here is a thread that has everything you ever wanted to know about seafoam.
https://www.yotatech.com/forums/f123...d-stuff-64836/
Redeth005
Jun 28, 2018 08:16 PM
urabus
Nov 10, 2015 07:38 PM
Chicken12
Oct 14, 2015 03:54 PM
sanctfy
Sep 13, 2015 06:33 PM
Boomer8404
Sep 10, 2015 09:01 AM
