Sponsored by: CARiD
86 toyota pick up
Old Mar 24, 2009 | 09:42 PM
dan8906's Avatar
86 toyota pick up
so i just bought an 86 toyota pick up, 22re EFI engine, with 146,000 miles and there is a modification but im not sure what it is used for, it is a button that makes the starter turn over, i have no idea what its used for!! any ideas??? also it has no AC what would be the cheapest and best why to add one!!!
Old Mar 24, 2009 | 09:55 PM
NorCalWheeler's Avatar
If I were you and depending on what you using the truck for I wouldn't put A/C in because it robs HP, but that my thought.
Old Mar 24, 2009 | 10:01 PM
camo31_10.50's Avatar
A/C compressor only robs horsepower while you have the A/C on...
if there is any HP rob while it is off....it might be 1/4 of one hp...because i can turn my A/C compressor pulley with my hand...EXTREMELY easily..(the compressor is good..it worked when i took the belt off)..
im guessing...just guessing now....
if you have a button...that makes the starter turn....im guessing its a push button ignition...just guessing...seen em on alot of Chevy Luv's.
o..and the cheapest..and best way to add A/C...is to buy a GOOD used compressor...and..assuming you have all the lines for the A/C..hook em up!!!...
make sure it has the R134A fittings though...
Old Mar 24, 2009 | 10:05 PM
yeah I wasn't sure if it robbed a lot, for some reason I thought it did.
Old Mar 24, 2009 | 10:09 PM
dan8906's Avatar
thanks, why would someone put a push button start in for? or pretty much just for the hell of it? and also how hard would it be to do the AC?
Old Mar 25, 2009 | 05:47 AM
myyota's Avatar
When you put the key in the ignition to start your truck does it turn over and start ?, the reason i asked is because when i got my 86 4Runner the previous owner had wired in a push button start switch because the electrical part of the ignition switch had gone bad, so instead of properly fixing the ignition switch by replacing the electrical part of the switch he rigged this half assed fix, so i ended up removing all of this mess and just replacing the ignition switch and everything works again.
Old Jul 19, 2010 | 10:06 PM
chuckbrofasho's Avatar
yea "myyotta" is right, i have this problem with my 83 truck but unfortunately i have not found out the problem after replacing the starter, ignition switch, and getting a new battery. if it starts not turning over when you turn the key, check the ignition switch and starter relay, if that's not it then you might have to live with the push button start.
Old Jul 20, 2010 | 02:37 PM
vitamint's Avatar
Same Problem
I have a '86 4-runner manual trans 22re.... and I have this stupid "safety" switch... I have replaced the starter, battery and still have no idea why it wont start.... When I turn the key after the button is pressed, sometimes it will start, other times I hear a single click, and a whining noise... Any Ideas?
Old Jul 20, 2010 | 03:24 PM
swampfox's Avatar
does the truck have a auto trans ? the switch may be there because the neutral safety switch is bad or out off adjustment .i don't remember the correct name for the switch.
Old Jul 20, 2010 | 03:29 PM
neutral start switch
Old Jul 30, 2010 | 07:10 AM
vitamint's Avatar
No it is a manual trans.... I tired a new starter and the same thing.... it makes one click, and then you hear a slight while... almost as if it is stuck on something... but I can't figure out what tho?
Old Jul 30, 2010 | 08:45 PM
check your voltage going to the starter. on both ends of the cable.
Colington
Mar 8, 2020 09:51 AM
crashburnoveride
Aug 28, 2015 09:20 PM
Daneums
Aug 20, 2015 05:36 AM
wilbertd
Jul 6, 2015 07:39 AM
