Sponsored by: CARiD
22R or 22RE?
Old Apr 16, 2009 | 12:33 PM
crazedingo's Avatar
22R or 22RE?
Ok, I have an 84 toyota 4x4. The guy I bought it from said the engine was the 22re out of an 81 toyota celica. Now on the tapetcover it says that it is a 22re but it has a carb on it. I ordered a water pump for an 81 celica but it has 8 teeth instead of 6 and it won't spin when installed. I found out that the 81 celica came with a 22r engine. I also found out that apparantly the E means it's fuel injected. So now I am confused. How can it say on the top 22re if it has a carb? Is this possible? How do I know what it truely is and what it came out of to know what to order the parts for?
Last edited by waskillywabbit; Apr 16, 2009 at 04:41 PM. Reason: Title clarity per posted sticky
Old Apr 16, 2009 | 01:10 PM
83's Avatar
83
The valve (tappet) covers are interchangeable between 22R and RE. I think some of the heads would accept either fuel injection manifolds or carbed intake manifolds. So you could have an older RE (fuel injected) engine with a carb. You could have just an older RE head. You could have a complete 22R (carbed) engine with just an RE valve cover. You really do need to find out what you've got, and what year exactly, before you can order parts for it. Got photos? Hopefully someone more knowlegeable than myself can help you narrow down the year and model.
Old Apr 16, 2009 | 02:01 PM
IngSoc's Avatar
Pictures are worth 1000 words.
Old Apr 16, 2009 | 04:02 PM
eddieleephd's Avatar
x2
does this carburator have a fuel injector in the top of it?
If so then it is a throttle body! I usually call them fuel injected carburators!
Old Apr 16, 2009 | 04:16 PM
1stgen4gunner's Avatar
Ok, now if you have a carb on that block, then you do not have a 22re (fuel injected), you have a 22r(carbureted). Now to clarify things up, what I am guessing the previous owner did, was swap the the 22r out of the celica into your truck, this is a 22r because toyota didn't introduce the 22re(fuel injected) until 1985. All the guy probably did was buy a 22re sticker and slap it on the front of the 22r, you can buy them anywhere.
By the way.... WELCOME TO YOTATECH!
sandyota
Feb 4, 2021 11:16 AM
cars-guy
Aug 16, 2020 06:59 AM
dumpster84
Apr 30, 2016 06:03 AM
cars-guy
Jul 11, 2015 07:51 PM
87blyota
Jul 10, 2015 04:31 AM
