Sponsored by: CARiD
Steering Issues
Old Apr 29, 2009 | 08:59 PM
mikes86yota's Avatar
Question Steering Issues
New here and need some help! I picked up an 86 truck with a straight axle conversion and 3" body lift. my front springs were flat, so i got a set at the local salvage yard. Just finished installing and didn't expect the extra 3" lift! I know I will probably have to adjust my pinion angle with some shims, but my main concern is that my drag link hits the rear u bolt when the steering is turned right. the angle seems real steap. Is there a longer pitman arm or other fix to reduce the angle and fix this problem? I also need to add some lift to the rear as I am 3" high in the front now. Thanks for any advice!
I failed to mention power steering has been added to this truck. It has a rancho dual shock steering stabilizer installed as well as new rancho shocks and hoops for 6" of lift.
Old Apr 29, 2009 | 09:06 PM
4Crawler's Avatar
From your description, it sounds like you have a push-pull steering setup from an '85 or earlier truck. If so, you'll likely need a dropped drag link, I think the one I used to run is from Superlift:
Could also be the spring pack you installed is too thick. With a dropped drag link you can also consider flipping the ball stud on the driver's side steering arm (ball on top instead of below) for added clearance. Or install crossover steering and get rid of the stock setup:
- http://www.4crawler.com/4x4/CheapTri...ng/index.shtml
Old Apr 30, 2009 | 04:28 AM
Steering issues
Thanks, I am checking on the droped drag link. Is it possibe to flip the ball joint on the stock link? It would clear the ubolt. I will post a pic later today.
Old Apr 30, 2009 | 10:56 AM
So how do you get the steering arm higher or out of the way outside of taking out a leaf? Is crossover the only way?
Old Apr 30, 2009 | 11:14 AM
4Crawler's Avatar
That is what flipping the ball does for you. It puts the drag link on top instead of under the steering arm
Old May 7, 2009 | 05:22 PM
steering arm ball removal
I understand how to remove the drag link, but what tools are needed to flip the ball. I worked a little tonight, but the rain washed me out (no pun intended). Do I need to remove it and take it to a shop with a press?
Old May 7, 2009 | 08:49 PM
4Crawler's Avatar
Grinder, press, welder at a minimum:
- http://www.pirate4x4.com/forum/showt...t=flipped+ball
Plus you need an adjustable drag link in order to be able to turn the socket on one end of it 180 degrees.
Old May 8, 2009 | 03:16 AM
Ok, thanks. I have a reputable and experienced aquataince who I am sure can do the weld. Your help has been greatly appreciated!
Zpd426
Jan 2, 2016 01:15 PM
Up&Down
Aug 11, 2015 10:04 AM
gillesdetrail
Aug 3, 2015 04:43 PM
gmonnie123
Jul 26, 2015 02:44 PM
yoterr
Jul 24, 2015 04:29 AM
