Sponsored by: CARiD
94 pickup 22re new motor power loss low acceleration
Old Mar 30, 2009 | 07:14 AM
poolhalljunkie74's Avatar
I just put a new motor in my 94 yota pickup. new head, reman intake manifold, new plugs and wires, cold air intake kit, rebuilt throttle body, new o2 sensor, all new vac lines. it idles at 800 rpm. I have very slow acceleration and no power uphill. it is gettin about 14 mpg. any suggestions would be greatly appreciated..
Old Mar 30, 2009 | 07:16 AM
83's Avatar
83
Timing?
Could be a lot of things, though..
Old Mar 30, 2009 | 10:17 AM
timing at 5 deg btdc, set with timing light. had the jumper wire set.
Old Mar 30, 2009 | 11:46 AM
83's Avatar
83
EGR. Fuel Filter. Vacuum lines hooked up correctly. Compression. Brakes dragging. Exhaust restricted. Plus a bunch of EFI stuff I have no idea about.
Tell us what you've ruled out & it will help narrow it down.
Old Mar 30, 2009 | 04:16 PM
jungle_runner's Avatar
any CEL codes in the system?
i'm having the same symptoms ... i have code 24 coming up and just did a test on the AFM using this test guide and found that the AFM is bad
i'm also going to replace the fuel filter
Old Mar 30, 2009 | 05:42 PM
no codes, brand new wix fuel filter, brand new flowmaster exhaust, new cat. conv, vac lines done according to the chilton repair manual, brand new hawk performance brake pads, summit drilled rotors. I dont know how to do a compression check, i will look it up in the chilton book. i took the maf sensor off and cleaned it up and reinstalled. no change. i will run a test to see it it needs replaced. thanks for all the suggestions....
Old Mar 31, 2009 | 05:10 AM
83's Avatar
83
Wow, you've done a lot! That must be getting really frustrating.
Old Mar 31, 2009 | 05:12 AM
83's Avatar
83
What's your history with this truck? Did you just buy it? You don't by any chance have something like 33" tires & stock gears or something?
Old Mar 31, 2009 | 05:16 AM
Very frustrating, but I don't surrender to gremlins...
Old Mar 31, 2009 | 05:22 AM
Had the truck about three years, I put it through the test went from 185k to 350k and blew up da motor in about two years, it set up for about a year before i started rebuilding it. everything worked fine on the truck, every sensor, relay, module, everything and after i put a crate motor in ???
Old Apr 13, 2009 | 04:07 PM
yotaguy89's Avatar
My guess would have to be your bearings. The truck i bought had the same problem with going up hills, and just wasn't getting as much power as i thought it should have. I had overheating problems with it also and took it into a shop. The mechanic fixed the overheating problem and said not to drive it. Because i needed new main bearings.
zd92655
Mar 6, 2022 12:58 PM
Team420
Jan 12, 2021 04:57 PM
serenity03k64
Jun 27, 2015 07:59 AM
Peteyg39@hotmail.com
Jun 26, 2015 08:15 AM
RTdawgs
7
Jun 16, 2002 06:37 AM
