Sponsored by: CARiD
Wilson or Firestik????
Old Apr 9, 2009 | 12:00 PM
mdgrmt's Avatar
I have an 02 4runner, i have an 8 $ antenna now... i need a bigger one, im looking under 5 feet for one. I found two, either firestik firefly or wilson silver load flex, which one???
Old Apr 9, 2009 | 05:16 PM
tc's Avatar
tc
I have never had good luck with fiberglass antennae. They always end up broke on the trail after getting into a tree or rock.
A stainless mid-load antenna has survived MUCH better on my rig.
http://www.truckers-store.com/store-..._40189373.html
Old Apr 10, 2009 | 11:51 AM
Steveh29's Avatar
I have a Firestik mounted on my roof and I've been happy with it. I've never whacked it against rocks though.
Old Apr 12, 2009 | 01:21 AM
SurfingDrunk's Avatar
i ran a firestick which i hated, switched to a k40 which i liked a hell of a lot better.
now i have a roof mount wilson 1000 that i couldn't be happier with!
Old Apr 13, 2009 | 02:58 PM
dlbrunner's Avatar
I have a lil wil Wilson. I like it, but it can get moved around in heavy brush. also the little allen key bolt that holds the whip to the base got all rusty.
It is a good solution, I didn't like the idea of mounting a firestick on the hood on the tailgate. I like the removability for "Stealth" that the wilson provides
Old Apr 13, 2009 | 03:01 PM
4Crawler's Avatar
I've had good results with both a 4' and now 2' Firestik antenna on my '85. Key is to mount it on a spring base, stiff spring for the 4' and above, medium or soft spring on a 2' antenna. I like the heavy plastic heat shrink on the Firestik, it holds up well to scraping on trees, rocks and parking garage ceilings. I like the tuneable screw in the end as well:
- http://www.4crawler.com/4x4/CheapTri....shtml#Antenna
Old Apr 13, 2009 | 03:30 PM
Corey's Avatar
Co-Founder/Administrator
Stiff spring here too with a 4' Firestik II antenna.
I have ran Firestik II antennas for years with great luck.
Even with them flopping back and forth when off road.
Old Apr 13, 2009 | 06:19 PM
tc's Avatar
tc
I could never get an SWR worth a crap with the spring installed.
Old Apr 13, 2009 | 07:35 PM
4Crawler's Avatar
I got 1.2 SWR or less on both my Firestik antennas w/ base springs. That does make the effective length of the antenna a little longer so it'll need a little more adjustment than without the spring.
Old Apr 14, 2009 | 12:56 AM
Corey's Avatar
Me too, my SWR is usually around 1.2 or so, that it also with a quick disconnect on it.
Peevedkitten
11
Aug 31, 2015 06:57 PM
msged2007
Aug 22, 2015 07:46 PM
91Toyota4x4
Mar 8, 2005 05:44 PM
jimrockford
Dec 1, 2004 04:17 PM
bobzemuda
Mar 7, 2004 07:04 PM
