Sponsored by: CARiD
dual exhaust?
Old May 7, 2009 | 06:42 PM
Mr.Matthew3's Avatar
dual exhaust?
hey guys,im almost finished rebuilding my 3.0 and i want to run dual exhaust when its done. my question is, will this affect my O2 sensor? because i only have one, so will i be fine running it on only one side? any feed back would be appreciated, thanks
Old May 7, 2009 | 07:13 PM
jpmountainboy's Avatar
isnt there two??? one before and after the cat??
either way, maybe you could put one of the o2 sensor trick sender ( i have no idea what its called, but it sends a normal signal no matter what.)
then just run the dual. I dont know.
Old May 8, 2009 | 12:05 PM
DragonLTD's Avatar
On the 3.0's there is only one 02 sensor...you could run dual exhausts after the cat if you really want a dual exhaust. IMHO i wouldn't run dual exhaust on a 3.0 that engine doesn't have enough power to take advantage of the dual exhausts...I have 2.5" pipe all the way back with a Magnaflow muffler and it sounds great and it is faster than most 3.0's (of course i have the heads ported and pollished...). Anyway let me stop rambling...good luck!
Old May 8, 2009 | 02:47 PM
cootees's Avatar
A lot would argue that 2.5" is too big on the 3.0.
If you want to run duals, go for it.. The easiest way would be to get a single in dual out muffler and just have the tailpipes custom made. I would suggest staying at 2" or if you must 2.25" at the most.
Old May 8, 2009 | 03:09 PM
alright, thanks for the info guys
Old Nov 16, 2011 | 04:26 PM
jimbob58's Avatar
You need to locate 02 after the join of exh. pipes.
Old Nov 16, 2011 | 04:29 PM
MaK92-4RnR's Avatar
congratulations on bumping a 2 year old thread.
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
Zach_trun
Jan 22, 2020 04:42 PM
Daenerysdad
Oct 1, 2015 07:33 PM
sonorn67
Sep 19, 2015 05:39 PM
