Sponsored by: CARiD
need help for ideas!!
Old May 7, 2009 | 07:44 AM
RobbinsRacing's Avatar
Unhappy need help for ideas!!
hey i live in Duvall area and my 86 4runner i got as a fixer-upper and well we got it running but it's still spuddering/loosing power whene you try to give it moderate amount of throttle. we've cleaned the injectors and changed the gas and the oil and filters. we are planning on checking the throttle positioning sensor today. i don't know exactly how to do that but yeah. if you have any ideas on things to try or why it's happening. it's been sitting for over 2 years before this.
echeing to get wheeling! if you can help then please and thank you.
Old May 7, 2009 | 08:42 AM
cootees's Avatar
Did you try a tuneup? cap, rotor, wires & plugs.
Old May 7, 2009 | 10:58 AM
wheatus's Avatar
replace fuel filters do a compression test and check the timing
Old May 7, 2009 | 11:05 AM
Kiroshu's Avatar
truck seafoaming it! if its been sitting that long its got build-up and cloggup from old gas and other things nasta..... other than that full tune-up! oil change.... fuel filter... airfilter.... Timing? EGR? any codes? check engine light?
Old May 7, 2009 | 03:45 PM
well i did most of that, change gas, filters, and well my best bet is the throttle position sensor is bad. but i just want to know what other peoplem think. before e spend the money.
Old May 7, 2009 | 09:57 PM
Kiroshu's Avatar
well theres only so much you can do without spending money.... check and if nessacary adjst timing... clean egr passages....clean throttle body....
corey519
Aug 12, 2015 11:12 AM
Up&Down
Aug 11, 2015 10:04 AM
Bawlzdeep
Aug 2, 2015 08:35 PM
Sr5crawler
Jul 31, 2015 12:32 PM
PlayAwhile
Jul 20, 2015 11:36 AM
