Sponsored by: CARiD
cant get 22r started
Old Apr 25, 2009 | 05:35 PM
tango71's Avatar
I just rebuilt a 22R 4runner engine and cant get it running. Before anyone says anything. I'm not a noobie to engines. I built many B and D series honda race engines in the past. This is my first Toyota.
The timing is set according to the haynes manual. Cam set with gear pin pointing up 12 o'clock. crank pulley with timing notch at 0. Distributor rotor at cyl#1.
I am getting fuel, I am getting spark. One thing I am not sure if is if my injector wires are mixed up or not. Unfortunetly the wiring diagram in the haynes manual for this car really sucks and is poorly described. I wish it was like the 92-95 civic manual, would been a lot easier to read the schematics.
anyway firing order is 1,3,4,2 now the haynes manual says the cylinder layout is 1,3,4,2 as from front to back. shouldn't it be 1,2,3,4 like any inline 4 cyl. Just wondering if this could be a typo.
When I turn the key it turns over and after a while it does something wierd, the engine will make this "choke" sound and put a major load on the starter and I see my battery gauge go all the way down, sort of sounds like it just inhaled a bunch of liquid and the engine slows, then it keeps turning normally and repeats this choking sound, sometimes it will have a backfire if I try to give it some gas, but only once in a while. Is it being flooded?
This is what leads me to think that my injector wires are messed up, the harness on this car is wierd there are 3 blue injector clips and one gray. they are not numbered though and they all seem to be the same length.
Does anyone have any guesses as to whats going on? maybe where I can find a proper wiring diagram for this truck. its a 1995 4runner 22r motor.
Old Apr 25, 2009 | 08:29 PM
tango71's Avatar
Oh one more thing. Does it really matter how I set my timing chain like it says to in the manual. Problem is that this is an aftermarket timing chain that did not have any marks on it like the factory one does. I figured that a chain is a chain and it doesn't matter how it sits.
I am assuming that as long as the crank pulley is at TDC and the cam has the pin that holds the sprocket pointing up to 12 o'clock. I am good. I've been searching around and saw an article that said that its possible to be 180 off on the timing.
87blyota
Jul 10, 2015 04:31 AM
raiderhawks00
Jul 8, 2015 06:23 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
colinmil
Jul 6, 2015 04:03 PM
karbin
Jul 5, 2015 11:37 PM
