Sponsored by: CARiD
Needing advice on leaking diff fluids
Old Apr 17, 2009 | 04:28 PM
motofox's Avatar
i have a 92 land cruiser, and its leaking what seems to be fluid from both diff's. the fluid is orange(ish), and is all around the diff. any ideas on what this could be?
Old Apr 21, 2009 | 10:44 AM
whokrz's Avatar
Check to see it the gear oil they used inside of the differential is orange(ish), if it is then your differentials are leaking.
Old Apr 21, 2009 | 11:14 AM
iselloil's Avatar
Make sure the breathers are not clogged.the diff wont vent,and will blow the seal, and or push fluid out of the diff.
Old Apr 21, 2009 | 11:31 AM
iselloil's Avatar
mistake
wrong post
Old Apr 21, 2009 | 03:37 PM
whokrz's Avatar
Originally Posted by iselloil
95 STANDARD CAB PICKUP 4WD,8000 miles since total rebuild. Every steering componet new,shocks, Sunwest 2.4 22re engine,new head,injectors, EGR,radiator,Zoom High performance clutch,pressure plate,balanced new flywheel,magnaflow, cat,new O2 sensor,muffler,new calipers,wheel clyinders,new universals,balanced drive shaft,new starter,alternator,new carpet,all fluids synthetic,class III hitch on front of truck,ARE topper more. 30x9.5x15 Firestone destination tires,$5500.00
93 4runner New 3.0 with 17,000 miles,new torque converter,exhaust,front axels,O2,Radiator,Mass air flow,Major Tune Up,Valve cover Gaskets done within 60 days,Trans has new kickdown cable,and all new seals,30x9.5 x15 BFG all terrains,Just sanded down and all rust taken care of in fiberglass and Painted. Has all the options.email me at iselloil@comcast.net for pics $5000.00
Your prices are a little high...... but why not just start your own thread?
Old Apr 21, 2009 | 04:06 PM
toyNG's Avatar
What the heck is this? I'm guessing you meant to put it in your own thread and put it here by mistake. Otherwise, one of the worst thread hijacks of all time.
Old Apr 21, 2009 | 04:25 PM
iselloil's Avatar
mistake
sorry guys, Had two windows open and keyed it in the wrong spot.
BigArt70
Jun 30, 2015 09:51 PM
AustinTaco
Jun 21, 2015 09:54 AM
MRael
Jun 19, 2002 08:28 PM
HALMAN
Jun 14, 2002 09:02 PM
