Sponsored by: CARiD
another one of those gears threads... lol
Old Apr 16, 2009 | 08:34 PM
Silas's Avatar
Well i've been doing some thinking lately, i'm pretty sure i'm gonna lift my 1986 4-Runner , slap some tires on it (33's ), and re-gear.
Its a 22re Automatic with the chain t-case.
Right now i've got 31's on it and its a bit of a dog. Actually, quite a dog with not much power. It gets maybe 300km to a tank if i'm lucky ( thats about 190ish miles ). But thats for another thread lol.
Right now the truck has 4.30's i believe, so i'm guessing if i found some 4.88 thirds i'd be all set to run the 33's ?? or should i grab a set of higher gears and get them installed ?
Also, how do the speedo's work in these is their color-coded gears for the number of teeth on them for the difference in gear/tire values? I'm assuming i'd want me speedo to be pretty close to dead on for the transmission to shift properly as its got the ECT thing or does that matter?
thanks.
Old Apr 16, 2009 | 08:36 PM
iamsuperbleeder's Avatar
4.56's might be just right, IMO
most running stock 4.10's will go to 4.88's when running 33's
coming from stock 4.30's, you may want to go a bit further to 4.56's
that should put you a little closer to stock speedo-reading and power
just my $0.02, but I'm not expert on gearing
Old Apr 16, 2009 | 08:37 PM
SpecialScottie's Avatar
From what ive read with the automatic your gonna want to gear it one step lower. So 5.29s for 33s
Old Apr 16, 2009 | 08:40 PM
89silverpu's Avatar
x2...auto and 33's = 5.29's
Old Apr 16, 2009 | 08:42 PM
Ive also got an auto in my 85 so Ive done a little research on this. Some will even recommend going to 5.71s with 33s
Im deciding between gearing it that low of just swapping in a 5speed
Old Apr 16, 2009 | 08:44 PM
89silverpu's Avatar
Your RPM's would most likely suck with 5.71's. Those are meant for ~37's and above from what I've read.
Old Apr 16, 2009 | 08:48 PM
I believe there are a few on here running 5.71s with 33s and the automatic. I could be mistaken though.
Anyone on here running 5.29s with a 4cyl, 33s, auto combo?
Old Apr 16, 2009 | 08:49 PM
Silas's Avatar
Ok so i'm leaning for 5.29's now... Thanks for the advice guys.
5-Speed is a nono, i want to keep the auto. 5.71s definetly way too high as well.
Old Apr 16, 2009 | 08:53 PM
89silverpu's Avatar
I think TC and a couple others are...
mskalmus
May 28, 2017 07:51 AM
wolfpackfan33
Aug 2, 2015 03:36 PM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
Gevo
Jul 29, 2015 11:15 AM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
