Sponsored by: CARiD
Need help with antenna.
Old May 3, 2009 | 10:35 PM
crazn's Avatar
So I installed the Pioneer DEH-P5900IB deck in my 1992. Now everytime I power the deck on, the darn antenna goes up even if I'm not listening to the radio. Is there a way I can wire the deck so that the antenna stays down unless I want to listen to the radio? The harness I got has 1 blue wire, and 2 blue wires from the deck that lead into one. I know the antenna cable needs to be plugged in for my rear speakers to work cause the amps run off the same power.
Old May 4, 2009 | 07:11 AM
Kinked's Avatar
do both the blue wires coming out of the deck have antenna on them.. or is one "REMO" or something like that.?
Old May 4, 2009 | 07:36 AM
scuba's Avatar
The Remo should be for a remote wire for an amp..
But there should be another cable that says "ant"
Old May 4, 2009 | 07:40 AM
904_runner's Avatar
when i first got my 90 it had a sony installed in it. and like you any time the stereo was on the antenna was up. well it broke from hitting a tree.
The first gens had a switch where you could raise/lower the antenna. i would look into that if i were you!
Old May 6, 2009 | 05:23 PM
Recoil's Avatar
same thing happened with my kenwood. I disconnected the antenna for a while, and just recently replaced it with an antenna from a pickup. It's not the same as the taco whip mod but it's a hell of a lot cheaper, the assembly/whip was only like $40 new from the dealership.
msged2007
Aug 22, 2015 07:46 PM
4x4Lamm
Sep 14, 2006 07:21 AM
Yota4runner
17
Jan 27, 2006 07:01 PM
Bob_98SR5
Jan 2, 2006 11:00 AM
Bob_98SR5
13
Dec 19, 2002 07:45 AM
