PDA
View Full Version : Newbie Tech Section
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 [47] 48 49 50 51 52 53 54 55
  1. Motor Question?
  2. Help! Torsion Bars?
  3. Replacing Leaf Spring Bushings
  4. brake pins
  5. pickup or taco
  6. 04 4runner wheel base
  7. Need Yota Tech Advice!!! Neeeed To Buy Relible Dd!
  8. Will 5/8s Bow shackles be okay for winchin'?
  9. 4wd conversion??
  10. 08 tacoma 4x4 old man emu
  11. Wheel bearings
  12. I love everything about my t4r except 1 thing
  13. prolem with geting power to fuel inside the fuel tank
  14. a/c leaking inside cab
  15. I Need A Rear Differential
  16. reg cab to extended cab
  17. Going against the grain?
  18. Truckmoto SAS vs. IFS
  19. Newbie with 86 4runner, loving it so far!
  20. would a 1986 front straight axle fit a 1990 toyota pickup?
  21. more power
  22. Flat bed conversion
  23. 2001 Tacoma out of gas
  24. rock crawler and towing gearing?
  25. 1987 4runner spark problems
  26. Bodylift and 37s
  27. Coolant Mix question
  28. Noob questions 1985 toyota
  29. just bought a 4runner
  30. Starting problems HELP!!!
  31. How do I fix this one?
  32. 84 5 speed in 86 pickup?
  33. replacing front wheel bearings
  34. dumb tranny question?
  35. clicking sound
  36. Oasis report?
  37. New..What to Look for?
  38. school me on tires/gears
  39. My 4Runner is going to make me beat my head in... with an impact hammer
  40. New Old Truck, need oil, filter, and other advice
  41. 83 problems...?
  42. Desperate for power!...and gas milage
  43. twinsticks
  44. Locking center dif?
  45. Any pics and/or info on Body armor fj bumper
  46. 2 oxygen sensors????? wtf
  47. Tranny ?????
  48. weird winding sound
  49. ball joint on 2000 toyota tacoma
  50. 99 tacoma e locker question
  51. any frame differences with '83 4x2 and '83 4x4?
  52. Can I change a 2x4 to 4x4 easily
  53. No dash lights
  54. Anyone with FJ lift pics on "stock" 265's?
  55. '89 4Runner runs rich after water hazard
  56. 86 4x4 need AC!! Unit is there, need tensioner?
  57. Am I Done for?
  58. finding parts
  59. Another '99 4runner lift question.....
  60. Front ball joints on 95 4runner
  61. Need help plz! Trans, engine problem?
  62. 4runner vs. pickup
  63. Ifs Vs Sfa
  64. odd item on ebay
  65. tacoma after market bumpers.
  66. drive shaft problem (maybe)
  67. 33x10.50?
  68. 33's on 4x4 86 pickup no lift or cut?
  69. 20r-22r
  70. Newbie body parts
  71. 91 center console?
  72. not able to time to 5 deg btdc
  73. need help asap
  74. Could the cyl. heads have been switched by accident on '95 4runner 3vze?
  75. 2wd ebay aluminum radiator
  76. Mud Run
  77. Parts for timing belt replacement
  78. Are all Toy 6 Lugs bolt paterns the Same?
  79. ball joint spacer question
  80. Changing a trashed cab w/same year?
  81. 79 truck lug pattern
  82. Fuel damper
  83. looking to lease a 4 runner
  84. 1987 4Runner won't start...
  85. 22re, Is It Worth It?
  86. Baja lift???
  87. gas tank
  88. Waterpump? For your entertainment and my help/sanity
  89. Suspensions questions
  90. My truck is a fussy starter!
  91. Gold vs Blue
  92. Water coming out of tailpipe?
  93. Injectors: 4 vs 6
  94. Won't stay runing!
  95. Hub Centric or Not
  96. adding power steering
  97. 87 4-runner power window question????
  98. Sunroof malfunctioning
  99. Blown Head Gasket?
  100. 4L Speeds/RPM'S
  101. Stuck Nut on my shock!
  102. 2" body lift advice
  103. sr5 cluster swap in 89 pickup problem!
  104. Alignment Issue: Inner Tie Rod End
  105. 91 4Runner idle
  106. help with exhaust choice.
  107. Vibration issues
  108. 2wd vs. 4wd 4runner
  109. 33" tires on stock lift 95 4runner.
  110. Newbie needs help with EFI Intake install
  111. Bull Bar question for my 02 Tacoma
  112. Shifter swap from G series to W series?
  113. $1000 4Runner
  114. 1996 2wd lift?
  115. URD s/c fuel upgrade kit
  116. heated o2 sensor for headers?
  117. bilstein HDs and sonoran 1.2 lift
  118. MAF Connector
  119. mystery electrical connector under the plenum
  120. Warm Idle Problems
  121. what is this canister? (1991 4runner 3VZ-E)
  122. 94 4runner rear main seal help
  123. Oil Question
  124. Newbie clutch question
  125. Need Advice for Various Elec. Problems in Back of 4Runner
  126. Toyota Mudding
  127. Need help with vibrations and poor performance
  128. Need Help with Replaceing Tailgate and window PLZ
  129. power to my cd player
  130. 07 Tacoma CD Player in 87 4Runner?
  131. Fuel Injection Electrical
  132. new cat...new (old) problem
  133. do i have longer than stock rear hangers?
  134. Wheel bearings replaced but now Manual Hub wont engage
  135. Speedo update and question...
  136. steering stab.
  137. Fuel Tank Part?
  138. Largest Tire that will fit is???
  139. Newbie here, with a ISR question...i only have one Hose??? why 2 fittings?
  140. Lost Keys
  141. Frame Painting
  142. Ifs lift, cant align, tire rods to long ?
  143. my first 86 4runner
  144. procomp prorunner light bar
  145. hose name?
  146. ANY help will Help
  147. Light bulbs?
  148. whats my gas tank size?
  149. nOOb just lifted 4runner. Got questions.
  150. Newbie needs some opinions.
  151. Key won't come out!!!!!!!
  152. 2nd Gen Runner bumper question
  153. frame swap
  154. power steering!!!
  155. Getting photos of your rig on here
  156. are wheel spacers ok to offroad with?
  157. speedo cable
  158. where can i find a header for my 22re?
  159. 95 tacoma front diff locked up need help asap
  160. Rear Pinion Nut...!!!
  161. tire and wheel about ready to fall off- help
  162. Amount of Oil/Block
  163. 03 taco what to look for?
  164. what for a fj60
  165. Help
  166. comparing 83 to 85 toyota trucks
  167. hubs on 95 pickup
  168. Carburated to Fuel Injected
  169. Weber 32/36 vs 38 mm for 22R
  170. Clutch/flywheel question
  171. Starting Problems
  172. '89 4runner CV axles same as '85 4runner?
  173. magna flow cat yes or no
  174. 95 2wd ecu on a 91 4wd
  175. What is the piece that goes over the rear tire on the door ('00 4Runner SR5)?
  176. ISR Mod/Deckplate
  177. Just bought a 94
  178. Toyota 22RE from Corona fit HiLux 4x4 G52 gearbox?
  179. Gaskets
  180. What valve covers will fit my 20r, and does anyone make aftermarket ones?
  181. Brake/ Axle swap
  182. 1988 3.0 fi miss and backfires
  183. truck won't start
  184. E-Locker Replacement Motor?
  185. Swapping bodies
  186. Getting hot !!!!
  187. Dolly towing question
  188. help on my 99 4runner
  189. Lift Kits
  190. Exaustes
  191. straight axle question
  192. from o2 to rear coils
  193. Im 15 and i bought a 1987 Toyota 4x4 (See pic)
  194. contacts in starter
  195. truck won't start
  196. 1991 4runner 22re overheating problem
  197. coil or ignitor??
  198. Anyone tried the 3.0 studs from D.O.A.?
  199. would a 22r header be ok on a 22re?
  200. compression check, newbie ?
  201. installin a lift
  202. 32s
  203. Check Engine Light
  204. 5.29 Rear ONLY ~OR~ Both Front "&" Rear
  205. Difference between Cail emissions and Fed?
  206. Best way to remove egr?
  207. Ebay Tierods?
  208. 94 2WD T4R code 71
  209. mud flaps, fender flares - tires too wide
  210. Head Gasket repair
  211. selling advice
  212. $500 '88 4Runner - Good buy?
  213. Engine just shuts off?
  214. Crossover Highsteer?!
  215. 06 Tacoma TRD suspension on a 95 4runner?
  216. Suspension Lifts
  217. Hard to roll backwards.
  218. A/C into an 88 EFI???
  219. Newbie here with an odd question.
  220. how to test?
  221. Gear and Locker decision, Need Help!
  222. help with exaust manifold
  223. 3.0 problems
  224. Exo Cage
  225. A couple of dumb questions,
  226. Leak from tranny pan!!!!
  227. $200 Battery Cable?
  228. pickup IFS beefing
  229. Ball Joints
  230. 22r headers
  231. hey, quick question
  232. Egr problem. 95 22re engine miss,stumble.
  233. Leaky Sunroof - New "fix"
  234. Why yesterday SUCKED!
  235. The oil filer on a 1982 Toyota Pickup
  236. audio system for my truck
  237. Driver side and Rear gate won't open
  238. 22RE Block vs. 22R Block
  239. Tranny capacity
  240. Question on clutch?
  241. Lookin for some advice.
  242. Ok so i got pics of my tailights!
  243. t-stat housing.
  244. EFI Fuse blowing...fresh rebuild PLEASE HELP!!!
  245. need some help please (starting-and info)
  246. good clutch for 4wheeling?
  247. Coolant/ Water leak 1992 3vz-e
  248. Better Snow Preformance?
  249. Goin to black out my lights!
  250. what diameter??
