Sponsored by: CARiD
ball joint spacer question
Old Jul 31, 2008 | 10:30 AM
gentry20's Avatar
if i put a 1.5in ball joint spacer what size shackles do i need to get to level it?
Old Jul 31, 2008 | 10:41 AM
Mic09dcsm's Avatar
Maybe 5 or 6 inch
Old Jul 31, 2008 | 11:26 AM
Yota Runner's Avatar
Originally Posted by Mic09dcsm
Maybe 5 or 6 inch
You wouldn't need any if you relax your torsion bars after the bj spacers. that way you would have a nice soft ride and increased travel. if you want lift out of them just stick them in and you would have 1.5" lift in the front then maybe go another 2" longer shackle than stock in back or stick in some small blocks.
my .02
Old Jul 31, 2008 | 04:37 PM
Jay351's Avatar
Screw blocks! Go with a 3" longer rear shackle. If you have the cash, I would throw a set of 63" chevys in the back.
Old Jul 31, 2008 | 10:16 PM
gentry20's Avatar
how much do chevy springs run. if i lift the back what should i do to lift the front.
Old Aug 1, 2008 | 05:11 PM
4Crawler's Avatar
If you want ~1.5" lift up fron, then 2"-3" longer shackle in the back would match that:
- http://www.4crawler.com/4x4/ForSale/Shackles.shtml#FAQ4
Kind of depends on how much you plan to lift the front:
- http://www.4crawler.com/4x4/ForSale/...cer.shtml#FAQ2
Chevy springs are probably $50-100 at the junkyard. Some fabrication and welding required to install them:
- http://www.pirate4x4.com/forum/showt...evy+spring+faq
krimsonone
Sep 13, 2024 09:33 AM
Sep 4, 2015 09:27 AM
4Runnin2000
Jul 29, 2015 06:09 PM
coffey50
Jul 28, 2015 10:55 AM
ksmudrunner99
Jul 21, 2015 05:33 AM
