Sponsored by: CARiD
94 4runner rear main seal help
Old Jul 17, 2008 | 12:47 PM
Bareass81's Avatar
Just took my truck for inspection and i was told my rear main seal was leaking, also my power steering pump was leaking. how long do i have with the 2 of them, and which should i take care of first??
Old Jul 17, 2008 | 01:34 PM
Jay351's Avatar
- Power steering leak, probibly due to use of power steering fluid instead of dextron lll tranny fluid.
How bad is the rear main leak? If its just a little bit of oil, you can live with it for awhile.
The rear main is more important for sure. Its also the harder one to fix.
I lived with a steering pump leak for a year before the pump went kaput. Used one is about 40 bucks...
Old Jul 17, 2008 | 02:39 PM
Bareass81's Avatar
rear seal
the seal just started leaking, and the same with the power steering pump. i think i am going to take ur advice and wait on the seal. i hope that it lasts until my clutch goes so i can do both at the same time. thanks.
Old Jul 17, 2008 | 03:30 PM
SEAIRESCUE's Avatar
Tighten all the oil pan bolts. That may fix the leak.
PS pump has a little "O" ring on the bottom of the removable reservoir. A 50 cent part and about an hour of labor.
Old Jul 19, 2008 | 10:07 PM
Jay351's Avatar
I don't think tightning the oil pan bolts will fix a leaky rear main...
But to the OP. Just keep an eye on your oil level. Make sure to check it every day or two. If it starts getting much worse, get'r'done.
voiddweller
19
May 2, 2016 09:10 PM
jennygirl
Nov 17, 2015 11:24 AM
Alaskan91
Sep 21, 2015 04:39 AM
Jmiller1023
23
Aug 6, 2015 07:03 PM
