Sponsored by: CARiD
a/c leaking inside cab
Old Aug 21, 2008 | 01:21 PM
barrelrolldougie's Avatar
ive got a 91 4x4 truck and the a/cs leaking inside the cab instead of outside on the ground..and it starting to smell..and tips?
Old Aug 21, 2008 | 01:54 PM
4Crawler's Avatar
Assuming you are talking about the condensing water dripping from the A/C evaporator inside the truck (was not clear in your post), it is probably a clogged drain tube. Clear it out and see if that helps. I have a writeup on doing that (not on a Toyota, though) on the web page below:
- http://www.4crawler.com/Diesel/Cheap...ml#ACDrainTube
Old Aug 21, 2008 | 02:37 PM
yea its leaking out of the evaporator, thanks man i hope thats it
Old Aug 21, 2008 | 05:37 PM
did some investigating im pretty sure its coming out of the heater core,which im pretty sure is inside the black box to the left of the air damper, anyone had this happen to them?
Old Aug 22, 2008 | 09:29 AM
Chainlink's Avatar
Yes, I have. I went to local pick and pull got a new core, couldnt figure out why it leaked (what failed). But the used one cleared up my troubles.
MO transplant
Apr 23, 2023 11:58 AM
Road Bull
Oct 10, 2015 04:55 PM
icentropy
Jul 14, 2015 10:23 AM
horunner1x
Jul 10, 2015 06:33 AM
bryan34w
Jul 6, 2015 05:53 PM
