Sponsored by: CARiD
1991 4runner 22re overheating problem
Old Jun 22, 2008 | 02:34 PM
914runnerjs's Avatar
I recently overheated my old stock 22re motor and ended up buying a rebuilt 22re motor at a shop. The stock motor had 214k miles on the thing. The problem is when I am driving at 65mph or idling the temp. slowly raises to 210 and stays around that area. When i am driving at 45mph the temp. stays around 190 but sometimes hits 200. I replaced the fan clutch, put it a 180 degrees thermostat 3 times, flushed rad. twice, bought a new rad. cap, and cleared all air bubbles by taking off the rad. cap and turning on the heat to FULL. I am not really worried about it staying around 210 since the motor still seems to run normal but when living in arizona and temps hit 115 degrees outside I really want to use my ice cold A/C but when I turn the A/C on it just raises to 220 and above. Im stuck and dont know where to turn now. Hope I gave a good description of my problem because im a newbie mechanic. Any help would be great thanks.
Old Jun 22, 2008 | 02:46 PM
Hilux808's Avatar
I live in Glendale so I know how you feel. I wonder if your cooling system has a blockage thats slowing the flow of coolant down, like your radiator might be plugging up. Check your belts and belt tension too.
Old Jun 22, 2008 | 04:14 PM
4Crawler's Avatar
Sounds like my '85 was doing when it had a partly clogged radiator. Take a peek inside the cap and see what the cooling passages look like. I put in a new GoDan 3-row radiator and it has run cool ever since:
- http://www.4crawler.com/4Runner.shtml#Engine
Old Jun 23, 2008 | 12:15 PM
I really think it is the rad too. I think ill take it to the shop for them to test it. The link you gave me dont work?
Old Jun 23, 2008 | 07:02 PM
4Crawler's Avatar
If you are referring to the link I posted, it works fine. What sort of error message did you get?
If your browser can't handle the target in the URL, try the top level page:
and click on the "Engine" link there.
the1998sr5
Oct 19, 2016 12:48 PM
Aleeex_u
Jun 5, 2016 06:52 PM
bobbybouche
Jun 18, 2015 10:22 AM
atticus
May 29, 2002 03:11 PM
atticus
7
May 26, 2002 12:14 PM
