Sponsored by: CARiD
Hard to roll backwards.
Old Jun 16, 2008 | 09:11 PM
shaw_j's Avatar
Okay, so this problem seems to be a bit confusing to my friends and myself.
As a few of you know I bought an 81 pickup a couple months back that is turning out to not be such a sweet find.
Heres the deal. With the transmission in neutral, I can easily push or pull my truck forwards, but can not push it backwards without extreme effort. With the transmission in neutral, and clutch engaged I have the same effects.
While on hills facing upwards the truck rolls back on it's own with the clutch engaged or disengaged, but when it comes to a stop, I still cannot push it backwards.
The truck has no issues with shifting into reverse, and seems to have no issues with reversing.
Info:
22r
4 speed
Stock gears
33s
LSPV has not been adjusted since the lift
This has really been troubling me, and is quite concerning. Thankfully for the time being, the truck is parked and not insured in my garage due to needing work, so time is not an issue with how long it will take to fix.
Any info I can get will be very much appreciated
Thanks in advance guys and gals!
Old Jun 16, 2008 | 09:15 PM
toytech76's Avatar
Check your rear brake shoes. They may be flexing and binding up when moved in reverse. Possible contamination of the shoes
Old Jun 16, 2008 | 09:16 PM
shaw_j's Avatar
Oh, and also, don't know if this could be causing issue - The E-brake seems to be a POS....
Old Jun 16, 2008 | 09:18 PM
toytech76's Avatar
ebrake issue=possible rear brake shoe issue
Old Jun 16, 2008 | 09:23 PM
shaw_j's Avatar
Thank you, I will look into that as soon as I have some free time
zeflower
Aug 30, 2015 06:52 AM
greyheadedguy
Aug 18, 2015 10:40 AM
DrZero
18
Jul 24, 2015 11:31 PM
RustBucket
Jul 24, 2015 04:46 AM
