Sponsored by: CARiD
Injectors: 4 vs 6
Old Jul 27, 2008 | 06:39 PM
jusfloorit's Avatar
Injectors: 4 vs 6
Are the injectors the same out of a 94 v6 and an 89 I4?
I can get some fairly new cheap and mine have over 200k on them.
Under 1500rpms, my truck lopes pretty bad then clears up after 1500.
I already replaced my ign components and it still does it.
Thanks.
Old Jul 29, 2008 | 01:54 PM
anotherjeff's Avatar
Buying new parts and hoping they may fix what's wrong, is a good way to throw money away!
Diagnose, diagnose, DIAGNOSE!
You may want to look close at the TPS and VAF...
Old Aug 2, 2008 | 11:55 AM
jusfloorit's Avatar
TPS is fairly new and what's a VAF???
Thanks
Old Aug 3, 2008 | 06:08 AM
VAF = Volume Air Flow meter.
Have you pulled the codes?
Old Aug 3, 2008 | 09:17 AM
Jay351's Avatar
Make sure you stick the M in there, VAFM.
Old Aug 3, 2008 | 09:40 AM
wrnchplr's Avatar
Engine (lopes at idle) could be a few things...
1. vacuum leaks... Intake, lines, EGR or a plugged pvc
2. Ignition parts...Timing belt worn, valve clearance, timing off,
3. Dirty injectors
4. could also be a issue with a head gasket or burnt valve.
If your wanting to change injustors there are some differences. some of the 4 cyl. one have 2 holes in the tip, the v6 ones only have 1. you can check the part number if they match then they will work.
Old Aug 4, 2008 | 09:07 AM
jusfloorit's Avatar
Prob. gonna replace the PCV. Motor has 55k on it. Timing belt should be o.k. Definately not head gasket. VAFM was refurbished by yours truly about 4 years ago.
Other then it running choppy under 1500 rpms, the truck runs great. It's just annoying when you pull away from a stop sign and it sounds like a POS.
I was just figuring it might be dirty/bad injectors not being precise at low rpms.
My friend has new injectors for the v6 that he's not using. I was wondering if they're the same flow rate (cc's or lbs per hr).
Thanks for all your input.
kdevine321
Aug 26, 2013 07:14 AM
eric_the_red
26
Apr 8, 2009 12:05 AM
j_cuz
Sep 3, 2007 09:03 AM
dlbrunner
Jun 14, 2007 05:53 PM
