Sponsored by: CARiD
Won't stay runing!
Old Jul 26, 2008 | 11:13 PM
1976jordan's Avatar
Won't stay runing!
Hey every one!
I have a 1991 V6 4Runner that stalls after about 30 seconds. The gauges die and the lights dim out as if the battery is dead, but the battery is @ 11-12 volts right after it stalls and it starts right back up and repeats this process so it can't be the battery or the alternator - I hope. (alt is brand new) What could be the problem? I'm new at this wrenching thing so any suggestions would be very helpful.
Thanx for your time
Old Jul 26, 2008 | 11:20 PM
hostile's Avatar
I had a problem similar to this on my buick and 2 weeks and 1500 dollars later it ended up being the computer. Best thing to do is take it to the dealer and let them check it out. Don't trust other shops.
Old Aug 15, 2008 | 05:46 PM
JDMSLIK's Avatar
I'd do some fuel system checks.
Mainly flow rate. You could have a plugged filter or a weak pump.
Was the vehicle hesitating while in use prior to this? What was it like going up hills?
Old Aug 15, 2008 | 09:45 PM
BigJake92's Avatar
Was it a New alt or a reman. If you bought it from auto zone i'd still have it tested??? Had a few bad ones at the shop . If thats o.k. Id check fuel pressure..
Old Aug 15, 2008 | 10:38 PM
Kiroshu's Avatar
Yea def Fuel filter or pump. Or check or air intake hoses for being loose or broke with holes in them.
Old Aug 16, 2008 | 09:14 AM
4Crawler's Avatar
Might have a look at the page below and give it a try:
- http://www.4crawler.com/4x4/CheapTri...shtml#FuelPump
moparbay
Mar 10, 2023 03:50 PM
noahstancik
Sep 10, 2015 10:47 AM
zz_denis
Sep 6, 2015 03:43 PM
