Sponsored by: CARiD
Ball Joints
Old Jun 13, 2008 | 03:16 AM
94_yota_pickup's Avatar
Ball Joints
Is there is certain way to check your ball joints to see if they need replaced?
Old Jun 13, 2008 | 03:35 AM
Team420's Avatar
Yeah, jack up your truck, and pull back and forth from the top and bottom of your tire, if there is movement...you need b/j's, also, use a bar and shove it under your tire, pull up on it quickly, kinda like popping it up, any movement would indicate bad b/j's, movement in all directions(back and forth, side to side, would indicate wheel bearings, and movement side to side only would indicate tierod ends, or inner tie rods. also...see this link
http://personal.utulsa.edu/~nathan-b...28balljoin.pdf
Hope this helps...goodluck..I am in the process of doing b/j's on my 94, and they are originals..with 200k...p.i.t.a.
kawazx636
Oct 6, 2021 03:03 PM
ladybugRC
458
Aug 21, 2020 10:41 AM
4x4YOTA
Aug 23, 2016 09:08 AM
crash813
Sep 27, 2015 07:15 AM
Odin
Sep 26, 2015 06:56 PM
