Sponsored by: CARiD
Dolly towing question
Old Jun 26, 2008 | 02:57 PM
wild_ks's Avatar
I found a 1986 parts pickup that has a bad ring and pinion gear. I would like to know what I could do to tow it with a dolly with the front wheels on the dolly. Could I remove the ring and install the carrier? Or is it safe to lock front wheels remove driveline and tow with with the rear wheels on the dolly?
Thank You
Old Jun 26, 2008 | 03:03 PM
wrnchplr's Avatar
I would buy a 3rd take it with you and drive the truck home. if your towing with the fronts on the ground don't lock the hubs.
Old Jun 26, 2008 | 03:06 PM
corax's Avatar
how does the rear sound coasting in neutral? how bad is the R&P? How far do you need to tow it?
as long as the diff bearings and axle bearings are decent, you should be able to just disconnect the driveshaft or put the t-case in neutral - that way there's no load on the R&P. That's only if it'll still freewheel or coast good . . . If the bearings are toast though, you won't want to go that route.
Old Jun 26, 2008 | 03:13 PM
wild_ks's Avatar
Lock the front steering is what I should have said. Truck does not run. I need to tow it about 200 miles. I have not seen the carrier so I do not know how bad the R&P are. Could I just build a cover and fill the differential with oil and leave the carrier out?
Old Jun 26, 2008 | 04:12 PM
dropzone's Avatar
Fossilized
If it is a bad rear, yes you can tow the truck with the front wheels on the ground rear on the dolley with hubs in neutral. the steering wheel should lock with the key removed. If not chain the crap out of it and check it often.
If it is a bad front than no issue with the front wheels on the dolley.
When ever flat towing (rear wheels on ground) you need to remove the rear driveshaft: (from http://pirate4x4.com/forum/showthread.php?t=459180
Originally Posted by Marlin Crawler
On all auto chain driven and manual gear driven t/cases, if it is towed in two wheel drive, the output shaft will turn, but there will be no way for the oil at the bottom of the case to get to the top where the output shaft is. On the chain driven cases, the input shaft turns the planetary housing which drives the oil pump. Gear driven cases use the input gear and low range gears to throw oil on the inside of the housing that collects the oil via gutters and directs it to the rear of the case by gravity. Both style of cases, must have the input shaft spinning to lube the output shaft, speedo gears, and rear seal of the t/case. The rear driveshaft must be removed.
Marlin
4x4-runner
Apr 18, 2017 09:08 PM
4x4-runner
Aug 3, 2015 07:14 PM
TJWilly
Jul 31, 2015 02:05 PM
vanion2
Jul 29, 2015 06:17 PM
pyramid
Jul 29, 2015 06:53 AM
