Sponsored by: CARiD
Help! Torsion Bars?
Old Aug 25, 2008 | 10:25 AM
Ryan's Avatar
Help! Torsion Bars?
I have a 86 4Runner I am in the middle of changing the control arm bushings. I need to release some pressure from the torsion bars so I can get the control arms off. So this is a totally stupid question to maybe some but I am totally stuck.
I have tried and tired to get both the back bolts on the torsion adjustment to release. Is there some kind of trick? I have the strongest air ratchet on this thing with a wrench on the back side and I still can not get the backing bolt or the other one loose. The torsion adjustment bolt does turn freely but I am not having any luck getting the thing loose at all. I checked the threads and they are not reversed so I am at a loss for words. I am heading out there with some WD40, maybe that will do the trick because 180psi air ratchet sure didn't help at all. Any tips here guys?
Here we see the top backing nut and bolt
Here we see the bottom torsion bar adjustment bolt. It turns freely as the top backing nut and bolt turn with it, HELP! LOL
Thanks guys for any help you can offer. If the WD40 works out then I will officially post up that I am a total nerd haha.
Old Aug 25, 2008 | 10:43 AM
dirtoyboy's Avatar
WD40 is weak sauce...try PB blaster instead...let it soak for a few days before you attempt removal and use the biggest breaker bar you can find/make
Old Aug 25, 2008 | 10:44 AM
dirtoyboy's Avatar
the truck is off the ground right?
Old Aug 25, 2008 | 10:51 AM
Ryan's Avatar
Nerd Alert! WD40 soaked in and eventually got these loose haha. I feel pretty dumb now but eh, I guess that is how we learn right?
ladybugRC
458
Aug 21, 2020 10:41 AM
choppe777
May 16, 2016 08:00 AM
A2theK
Oct 14, 2015 07:10 AM
Obmi
Oct 4, 2015 11:30 AM
HiLuxer
Sep 9, 2015 02:43 PM
