Sponsored by: CARiD
drive shaft problem (maybe)
Old Aug 4, 2008 | 05:10 PM
4runnerempire's Avatar
ok so i just bought a 1988 4runner and it has a poorly done block lift of about 3 inches and 32 bfg's on it. It had a blown diff so i got the axle codes and went to put the diff from my parts truck in it (both have a g292 axle code). the problem is that the plate on the end of the drive shaft is bigger than the plate on the diff. the guy said it was a stock drive shaft. also the drive shaft from my parts truck is to short. In the end my question is A: are the plates on a 22re smaller than the one from a 3vz even though they have the same axle code? and B: If it really is a stock drive shaft in the new truck why is the one from my parts truck to short?
new truck has 3vz parts truck was a 22re
Old Aug 4, 2008 | 05:59 PM
Jay351's Avatar
The flanges on the diffs are different on the 22re/3vze equipped trucks. You should be able to re-drill the flange and make it work. Or you can swap out flanges.
were both the trucks manual or auto?
Old Aug 4, 2008 | 06:13 PM
a4runnerfreak's Avatar
From: Grew up in S.C.V, So Cal.....now in Hampstead, NC
Sounds like 1 is m/t and the other is a/t. If I remember right, the m/t driveline is the longer of the 2
Old Aug 4, 2008 | 07:29 PM
Jay351's Avatar
Yes, The M/T rear driveshaft is longer...
Old Aug 5, 2008 | 04:50 AM
both trucks are 5 speeds but i think i am going to double check the vin on the parts truck to make sure.
Charecter1
Nov 6, 2023 10:08 AM
andrewtexas123
Jul 14, 2015 04:29 AM
Avenged
Jul 9, 2015 07:55 AM
Jnkml
Jul 6, 2015 01:20 PM
wilbertd
Jul 6, 2015 07:39 AM
