Sponsored by: CARiD
clicking sound
Old Aug 14, 2008 | 02:47 PM
yoder519's Avatar
clicking sound
when im drivin theres a clicking sound at my front wheels. is it the CV's or what? also, should i fix this before i put on bj spacers and crank my tbars out a little?
Old Aug 14, 2008 | 02:49 PM
jimbos_4runner's Avatar
when i full lock to one side i think its to the left which is my passenger side, the runner doesnt like it, and it makes a really loud ticking sound i think thats the best way to describe it, ummm i think it is my CV joint but havent had enough info to make sure of it or not???
Old Aug 14, 2008 | 03:12 PM
4Crawler's Avatar
Manual hubs or does it have the ADD front axle?
Old Aug 14, 2008 | 03:16 PM
yoder519's Avatar
yea it has manuel hubs
Old Aug 14, 2008 | 03:22 PM
all i know is that my runner has independent rather then straight thru, lol its probably irrelevant, tot eh question, but i do think i need to replace my cv joint it said it was cracked on the test papers when i purchased it, just been lazy, been to worried about putting bigger tires on it and making it look better on the inside!!!
Old Aug 14, 2008 | 03:36 PM
yoder519's Avatar
yea i hear ya brother! same hear except tires/lift
Old Aug 14, 2008 | 08:12 PM
Jay351's Avatar
Does it click when the hubs are unlocked? If it only clicks while they are locked then I would guess the cv joint(s) are gone.
Old Aug 15, 2008 | 02:32 PM
yoder519's Avatar
yea it only clicks when theyre unlocked. i really havnt paid attention to see if it does it when theyre locked in
Old Aug 15, 2008 | 04:11 PM
4Crawler's Avatar
If hubs unlocked (and they are actually unlocking), then the CV joints will not (or should not) be turning. Might be worth rebuilding the front hubs and see if that helps:
- http://www.4x4wire.com/toyota/maintenance/front_end/
Old Aug 15, 2008 | 06:09 PM
yoder519's Avatar
well it kinda to me sounds like its just the right side that makes the sound. so should i just rebuild the right one or go ahead and rebuild both?
Old Aug 15, 2008 | 06:15 PM
4Crawler's Avatar
Probably wise to do both sides, but try the right side first. Once you clean up the parts, you may see if anything is worn or damaged and can go from there.
Old Aug 15, 2008 | 06:17 PM
yoder519's Avatar
alright thanks ill give it a try when i get a chance. thanks a bunch
Anthony Lee Mathis
Sep 15, 2015 07:22 AM
May-39
Sep 6, 2015 01:05 PM
larrys93pickup
Sep 6, 2015 06:37 AM
some drunk guy
Sep 4, 2015 11:55 PM
BigMike
Marlin Crawler
Sep 3, 2015 07:49 PM
