Sponsored by: CARiD
Locking center dif?
Old Aug 11, 2008 | 06:52 AM
51050larry's Avatar
Junior Member
Locking center dif?
I have a 02 4rnr and only went offroad a couple of times. I was reading the manul (what a concept) and came across the section on the Center Locking Dif button. I have used 4WD but never new what this was for. The book does not give you much of a definition. Could someone clue me in on when I would need to use this while playing offroad?
Old Aug 11, 2008 | 07:05 AM
4Crawler's Avatar
You would use that when you get into a situation where you find one axle having traction problems. With an open center diff, if tire(s) on one axle lose traction, you are stuck. With the center diff. locked, you need to lose traction on both ends before you are stopped.
What kind of terrain? Climbing steep hills or ledges where there is little weight on the front end for example.
Old Aug 11, 2008 | 08:41 AM
DeathCougar's Avatar
4Crawler: I think you are talking about diff lock, not center diff lock. Center diff lock on 01+ 4Runners refers to the transfer case, since they did not offer a diff locker on the 4runners after 2000.
Center diff lock in Laymans terms:
The transfer case is locked together in "Center Lock Mode" so the front and rear driveshafts spin at the same time, no matter what.
Having the center diff lock unlocked is like having 1wheel drive when you lose traction offroad.
Old Aug 11, 2008 | 08:49 AM
4Crawler's Avatar
I was referring to the Center Diff Lock and as you note (and I noted) it locks the transfer case differential such that torque can be sent to both axles. With it open (unlocked) lose traction on one axle (front or rear) and no torque is sent to the other axle. Lock it and toque will be sent to both axles regardless of the traction.
Old Aug 11, 2008 | 08:54 AM
Ok, makes sense. I was just making sure, since your post was a little confusing. Especially for the n00bs lol
Old Aug 11, 2008 | 10:22 AM
eric-the-red's Avatar
I have an 01 with the centre diff lock and I use it for slow crawling on rocks or very loose stuff. Like Roger said it's useful any time you could get a wheel off the ground or loose traction on one end.
One thing to remember is you need to drive in a straight line for about 20 feet or so while it locks. So turn it on before you get stuck.
justdifferentials
Just Differentials
14
Sep 24, 2017 08:32 PM
justdifferentials
Just Differentials
Aug 15, 2015 05:25 PM
Up&Down
Aug 5, 2015 06:20 AM
TDonkey
Jul 26, 2015 10:14 AM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
