Sponsored by: CARiD
t-stat housing.
Old Jun 8, 2008 | 04:14 PM
89trknwby's Avatar
t-stat housing.
I have a 89 pickup , 4x4 , 22re with 5 speed tranny. I have been using the search loking for answers and have found most but one. what is the sensor looking thing on top of the t-stat housing? is it suppose(spelling?) to be plugged in? if so , where and what color wire? also , which of the two sensors in front of the intake would be the coolant temp sensor? the left or right? Thanks for the help.
Old Jun 8, 2008 | 05:01 PM
89trknwby's Avatar
found out which one is the coolant temp. sensor. would the one on top od the t-stat housing be the knock sensor?PLEASE HELP.
Old Jun 8, 2008 | 05:27 PM
89trknwby's Avatar
it's not the knock sensor. found the knock sensor. anyone?
Old Jun 16, 2008 | 05:37 PM
89trknwby's Avatar
Please help. my truck is running like crap. I want to figure this out with out putting a bunch of money into parts for it to not fix the problem.
Old Jun 16, 2008 | 05:55 PM
4Crawler's Avatar
If only one sensor atop the housing, it is one of the following:
- A/C high temp cutout (if A/C installed)
- A/T engine temperature (if A/T installed)
- Turbo high temperature cutout (if a 22RE turbo engine).
Pull any stored trouble codes in the engine computer for starters:
- http://www.4crawler.com/4x4/CheapTri...CheckConnector
Old Jun 16, 2008 | 06:12 PM
89trknwby's Avatar
thank you very much!! the a/c has been removed. I pulled a code 14 . which is ignition signal. " no IGF signal to ECU 6-8 times in succession. " igniter and ignition coil circuit or igniter and ignition coil. would that cause it to take a few seconds to start . it cranks for almost 10 seconds before it starts then it idles rough for about 5 seconds . after that it idles fine, but when i get on the gas it sounds like it is miss firing. would a bad coil cause that? or a bad igniter? Thanks again!!
Old Jun 16, 2008 | 06:16 PM
4Crawler's Avatar
Try this for starting:
- http://www.4crawler.com/4x4/CheapTri...shtml#FuelPump
And make sure there is a good vacuum line connected to the fuel pressure regulator (on the back end of the fuel injector rail):
- http://www.4crawler.com/4x4/CheapTri...ine_Pix/8.html
Old Jun 16, 2008 | 06:37 PM
89trknwby's Avatar
thanks again. i went out and looked. the vsv is unplugged and the vac. line rune from the sid eof the intale rail to the fpr. should i hook the vsv back up?
Old Jun 16, 2008 | 06:42 PM
4Crawler's Avatar
That is how I have mine run, as long as that vacuum line and port is not clogged internally, it should be fine. That just adjusts fuel pressure based upon engine load. Sometimes if that line is disconnected, you'll see too high a fuel pressure at idle and that can make the engine bog down until you hit around 2000 RPM or so.
Old Jun 16, 2008 | 06:50 PM
89trknwby's Avatar
Thank you again. I'm going to try the jumper for the fuel pump after work tomarrow. Thank you again.
Longbed 90
Mar 11, 2019 12:38 PM
A2theK
Sep 30, 2016 12:50 PM
LotOMiles
Sep 14, 2015 11:45 PM
trailgoat
Aug 13, 2015 05:54 PM
Poncho0206
Jul 10, 2015 06:21 PM
