PDA
View Full Version : Newbie Tech Section
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55
  1. 99 tacoma cluth problems
  2. 82 L45 4 speed transmission issues
  3. Skid Plate for 4" Rough Country Lift
  4. Too much bed movement
  5. Popping out of 4hi
  6. Alright, I'm desperate and I know it
  7. 4wd not working
  8. Coil Pack Spec Range
  9. Gauge Cluster Swap
  10. oops wires
  11. What size OME springs and shocks to buy?
  12. 1990 1 ton dually ewds
  13. 3.4L 5VZ-FE V6 Overheating at high RPM
  14. What black wheels look best on 1994 Pickup??
  15. Will these tires and wheels fit with this lift???
  16. oil leaks
  17. 93 SR5 rear driver tire sticking
  18. knock sensor differance
  19. 07 FJ Block Heater Repair/Replacement Options
  20. Tech Test ...thread pitch..Project Pickle
  21. What is the name of this part and what does it do?
  22. Need help finding hub assembly!
  23. New Engine, Fuel Issue
  24. 2001 4 runner fender flares
  25. Flywheel alignment
  26. Concept
  27. 85 4runner map light
  28. 22re died, started, & now nothing? Plz help. Thanks.
  29. help - lift and tire input needed
  30. Will 2001 Tacoma rims with tires 225/75/16 fit on a 2002 4runner
  31. lifted ifs trouble
  32. Suspension & Steering questions
  33. Stumped!!!!!!!!!!!
  34. Old Man Emu 2" lift and setup questions
  35. Fuel Pressure Damper/Regulator?
  36. steering column short
  37. 22RE Why your idle is rough or missing
  38. Safe to disable PS gearbox?
  39. Death wobble?
  40. Front 3rd member swap walkthrough
  41. Oil dipstick replacement
  42. 95 4 runner advice
  43. 95 4 runner advice
  44. Engine noise, code 13 and 42 help
  45. Stealership Lies- U Joint Issue- Opinions Needed
  46. 5VZ-FE (3.4) Timing Belt
  47. 2001 4runner Sr5 2wd have to let go of gas gor next gear
  48. Towing a 4runner?
  49. best year motor for a swap
  50. wrong gears
  51. sas steering box location and rear lift
  52. Testing Fuel injector
  53. Brake swap on solid axle truck
  54. Repairable frame?
  55. Different keys for ignition and doors?
  56. New here
  57. Squealing sound in front end or ?
  58. Transmission dipstick housing bolt
  59. Motor oil in clutch master cylinder
  60. 94 toyota 4x4
  61. 22RE Rough Idle
  62. 1985 Celica GT
  63. little help
  64. 82 4x4 front driveshaft/t-case leak
  65. Exhaust manifold gasket on wrong side?
  66. Transmission Fill Plug Help
  67. Help injector wiring
  68. P0170... tried everything I can think of. Running rich at idle.
  69. fuel problem
  70. no power off idle
  71. '76 Chinook - what kind of batteries?
  72. Steering box question
  73. 3VZE/3.0/V-6 Head gasket question
  74. Will 31 inch tires fit on my 84 pickup?
  75. cv axle trouble
  76. VSV for AS help
  77. engine noises
  78. 5vzfe Water Pump replacement w/o changing timing belt?
  79. Help - '92 pickup 22re idle issues
  80. Problem 1987 22R 4X4
  81. Greetings also a newbie question
  82. Common valve-train issues with 3.0
  83. Spring-under conversion for no-lift crossover steer?
  84. 93 sr5 4x4 pickup rough idle
  85. 91 Pickup 3L V6
  86. Clutch Master Cylinder Problems
  87. what wheels will fit 1985 4runner
  88. I have a problem in the cold
  89. exhaust manifold leak 1998 4runner
  90. Shift solenoid b po755
  91. 1998 4runner compression test
  92. the toyota dealer told me I need a new engine...
  93. Newbie Question Marty Mcfly BTTF Truck.
  94. alt light came on
  95. Frame plugs?
  96. QUICK Question - will tire size work without lift?
  97. Face Gauge
  98. Oil leak
  99. 91 3.0 4runner running rich.
  100. Head gasket nightmare
  101. No start after timing belt change T100 DX 1995 3.4 L 5VZFE
  102. 97 4runner limited 4x4 - proper use of 4wd?
  103. fuel line fail
  104. help with tranny lines
  105. Identify this plug for me please.
  106. trans won't go into first
  107. dead guages HELP!
  108. 1994 4x4 dlx automatic shift problem
  109. Battery Recommendation?
  110. No heat!!!
  111. T case @ tranny leak
  112. Will 4wd cab fit on a 2 we frame
  113. SAS Into an 88 Toyota pickup 4x4?
  114. Where to start my build
  115. 3vz emissions question
  116. Power steering pump bearing
  117. Yota build
  118. crazy squeaking noises
  119. What does this sound mean?!?!
  120. 2003 Tacoma - 4x4 does not engage
  121. Digital clock problems help pls
  122. Clutch replacement questions
  123. 4h engine clunk when ignition turned off
  124. Yotatech Garage Meet-Ups?
  125. throwout bearing clips falling off
  126. Transmission flush
  127. ABS problem
  128. Will OG steelies clear LC/V6 brakes?
  129. 22re idle issue
  130. 91 4Runner Tail Gate Key
  131. 3rz oil pan
  132. Shaking when in gear
  133. 3.4 cyl 2 compression 60psi wet, no change
  134. 3vze ecm enters open loop with out a cel
  135. 94 Toyota 22re won't start
  136. wires on right hand side of transfer case
  137. 96 4Runner Problem - Steam in Cab
  138. New member
  139. Can someone identify this slight "squeal" in 3VZ-E?
  140. Help!- suggestions for 86 22RE rebuild kits
  141. 1990 3VZE Auxiliary Air Control Valve Not Functioning
  142. Oil Pressure gauge stuck on Zero
  143. 1994 SR5 pickup started running rough and pinging real bad
  144. 93 Toyota head gasket replacement need guidance
  145. Bad knock sensor causing AT issues?
  146. flashing 4wd lights fixed!
  147. 2009 tacoma with 2.7 will not idle after battery disconnect
  148. 1991 Pickup downstream o2 bypass?
  149. 3.0 to 3.4 swap expertise needed
  150. 22re sputtering
  151. Timing chain replacement
  152. Help me ID choke parts on 22R? Please?
  153. 1985 Toyota 4X4 driveshaft issues
  154. Needing Some Advice For Truck Build
  155. 91 toyota pickup
  156. 91sr5 cab help!!
  157. COILED rear question!!!
  158. mystery plug
  159. 1997 Toyota T100 Caliper question
  160. 93 will not run
  161. 2RZ AFR readings
  162. Could having the timing advanced too far cause OBD code 52?
  163. Using starter fliud
  164. Flywheel step
  165. EGR 3vze question
  166. What part is this?
  167. T100 rear bumper help
  168. Driveshaft removal
  169. Radiator AGAIN!!! see no flow through cap???
  170. 89 22re need help. Runs crappy and dies
  171. 22r will not idle
  172. 1988 Toyota Sunrader
  173. 95 4runner rear sag
  174. helpp 1981 22 blowing fuses
  175. 20 years of 4Runner
  176. Fuel line for 95 4runner
  177. 1997 Tacoma oil filter tips?
  178. my 88 'Runner - 2.4L EFI DLX
  179. 3 slow probs
  180. 1986 22re Sr5 CEL code 4
  181. gentex mirror
  182. a/c console lighting
  183. Dexcool?
  184. dual rear wheel info
  185. drum removal/rear dual wheel
  186. Diagnostic help
  187. 22re Rod Knock
  188. Manual locking hubs
  189. 81 4.3l swap tranny needs replaced
  190. Fuel Pump stuck on
  191. 2RZ EGR/Oxygen sensor port on manifold?
  192. Help it's killing me a fuel bath problem
  193. gear shift assembly swap 4Runner 2WD
  194. 1994 toyota 4x4 shortbed 42000 miles
  195. 95 22re in an 83
  196. wiring to diesel fuel pump
  197. 93 Truck Dies when braking
  198. Clutch release cylinder?
  199. Toyo 4runner 2003 codes??
  200. Variable resistor adjustment, reading voltage on Vf1
  201. stumbles and surges at accelloration
  202. '82 Coolant sensor switch? Difference between the two?
  203. 96 3.4 performance upgrades
  204. Very strange but specific 95 4runner ignition issue
  205. Gas Pedal
  206. Driveshaft installation question
  207. Which yota?
  208. 1979 yota lift kit?
  209. Oil capacity 22r
  210. Full fluid change '99 4 runner V6
  211. Build advice (05 SR5 4runner)
  212. 84 22r dual row conv q
  213. new at this coverstion stuff
  214. sporadic hard shifting in first gear
  215. Questions on 95 4runner 4.3 swap gearing
  216. Cant check cel codes?
  217. 3.0 Whine Noise with new timing parts
  218. missed applying sealer before head torque!
  219. Vacuum
  220. Engine lag on acceleration
  221. Things to do with your 4runner
  222. 1992 toyota 4 runner V6
  223. my truck
  224. 88 22re over heating and had piece snap off
  225. Question about swapping in new gears
  226. Engine Rebuilding Question
  227. Carburetor Not getting Fuel
  228. Just a FYI
  229. high steer install
  230. 95 T100 5VZ-FE Wont turn over
  231. Recomendations 94 4runner
  232. new guy mods and stuff
  233. 94 toyota pick up 4x4 rubbing noise
  234. Rumble/Groan during downshift
  235. 3vze Head Problem
  236. 2007 Tacoma question
  237. help with installing window
  238. Another 3.0 idle thread...
  239. body lift
  240. Complete harness
  241. 22r Highway Cruising Speed
  242. 87 4Runner rear drum removal help
  243. Rhino Liner advice...
  244. Oil Pan Removal
  245. New here guys. own a 95 4runner
  246. 1990 to 1988 RE SWAP
  247. are 1982 22R-E parts the same as '84 22R?
  248. Which Cat?
  249. I Tried To search
  250. Coil over swap on 2nd gen
