Sponsored by: CARiD
1998 4runner compression test
Old Dec 3, 2014 | 06:18 PM
treeman89's Avatar
I have a question regarding my recent compression test on my 1998 4 runner 2.7 litre.
Is this considered good? What is considered Factory Compression?
CYLINDER 1-210, CYLINDER 2-210, CYLINDER 3-200, CYLINDER 4-200 PSI
Old Dec 3, 2014 | 06:54 PM
thefishguy77's Avatar
They are all with in 5% of each other so that is good. Just look up what they are supposed to have a did you close then you good to go. Most important this is all cylinders should be close to the same.
Old Dec 3, 2014 | 07:20 PM
treeman89's Avatar
Thanks. Where would i look to see factory compression specs? I'm having a hard time finding that on info!
Old Dec 3, 2014 | 07:41 PM
rworegon's Avatar
Take a look at the 1st link in my sig below. You may find something useful.
Old Dec 3, 2014 | 08:01 PM
treeman89's Avatar
HMM THANKYOU!
So from what i read my 1998 4runner with normal compression pressure would be at 178psi and minimum should be 128psi. So what exactly does this mean?
I had a shop do it but should have got a proper explanation. on a scale of 1-10 what would you rate this lol? I just wanna know if its a strong engine im thinking of investing in a lift kit and new tires. Don't wanna build it up unless its a solid rig.
Also right now it is completely stock. I am only getting 14mpg which seems low for an auto 2.7.. Is there anything i can do to improve this? Already i've had a tune up done. Cleaned throttle, cleaned idle control valve and put a seafoam additive in with a fuel tank of 91.
Thanks guyS!
A2theK
Jul 12, 2015 10:46 AM
crashburnoveride
Jul 10, 2015 06:39 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
colinmil
Jul 6, 2015 04:03 PM
Jnkml
Jul 6, 2015 01:20 PM
