Sponsored by: CARiD
5vzfe Water Pump replacement w/o changing timing belt?
Old Dec 8, 2014 | 09:53 PM
RyanFXR's Avatar
Question 5vzfe Water Pump replacement w/o changing timing belt?
From what I see in my FSM it looks like you can replace the water pump without having to mess with the timing belt, is this possible? I know for sure the timing belt is good and I suspect the water pump to have gone out prematurely due to only water being ran through the cooling system instead of coolant. ( not my car btw).
Old Dec 8, 2014 | 10:07 PM
wyoming9's Avatar
Red face
Since the timing belt drives the water pump your going to remove it any way.
Sure water pumps get changed all the time or other front engine parts.
The timing belt can be reused but you are messing with it no matter what.
Just how many miles as your right there .
No matter what you have to go through the process the same as if installing a new belt.
Do you have the tool for pressing the tensionor in and putting the safety pin in??
Old Dec 9, 2014 | 02:01 AM
rworegon's Avatar
Not possible. The timing belt must come off to get to the 5vz-fe water pump
Old Dec 9, 2014 | 02:13 AM
RyanFXR's Avatar
Thank you both for the quick reply's, after looking up some parts online I realized the part I was seeing was the fan bracket as the picture in the fsm looked similar to the water pump on a 350 small block.
Old Dec 9, 2014 | 02:40 AM
rworegon's Avatar
If you need a timing belt kit with water pump, check out seller AirCabinMan on eBay. He has kits with Toyota OEM parts that are hard to beat price-wise.
Old Dec 9, 2014 | 11:55 AM
wyoming9's Avatar
Red face
I wonder where they come from I looked over the weekend around $275.00
Will it heat the shop??
voiddweller
19
May 2, 2016 09:10 PM
Ichneumon
Sep 27, 2015 04:21 PM
Mutinebullfrog
Jun 18, 2015 01:36 PM
infinityisfive
Jun 16, 2015 06:51 PM
