Sponsored by: CARiD
93 SR5 rear driver tire sticking
Old Jan 12, 2015 | 05:08 PM
hudsyota's Avatar
Hello, I have a 93 SR5 v-6 manual transmission. The problem I am having is when I start out the rear driver tire will drag. This only happens when I drive forward not in reverse. I can stop an back up and sometimes it will break free. Is this a brake issue or is it the splines on the spindle? Any thoughts?
Old Jan 12, 2015 | 06:19 PM
thefishguy77's Avatar
Welcome to yotatech. A few questions first. Did your truck just start doing this or has it been doing it for a while? Have you done anything recently with the breaks or rear end? It could be something simple like the rear breaks are out of adjustment. If you just did the breaks this can happen. Also if the breaks need to be replaced they might be causing problems as well. Any squeaking in the breaks before this happened?
Old Jan 13, 2015 | 06:27 AM
hudsyota's Avatar
No I haven't done anything with the brakes, but the truck does not get driven a lot, and it tends to happen more in the winter than the summer.
Old Jan 13, 2015 | 12:21 PM
wyoming9's Avatar
Red face
Emergency brake sticking??
Leaking wheel seal getting gear oil on the shoes.
Old Jan 13, 2015 | 05:37 PM
hudsyota's Avatar
No that works fine.
Old Jan 14, 2015 | 04:06 AM
hudsyota's Avatar
Another guy said something about the splines on the rear spindle not meshing with the rear end. Could this be the problem and how difficult of a fix would it be?
Old Feb 4, 2015 | 05:12 PM
hudsyota's Avatar
still open to suggestions on this issue, I am driving the truck more frequently now and it seems the tire s locking up way more on below zero days
Old Feb 4, 2015 | 05:21 PM
JasonYota's Avatar
Take the rear drums off and see what's going on. When it froze down here last year mine would have water freeze inside the drum after a creek crossing and letting it sit a few hours.
Old Feb 4, 2015 | 05:24 PM
Odin's Avatar
I'd be very surprised if it wasn't one of these or a stuck star wheel adjuster.
Jun 1, 2021 01:51 PM
lledwod
Aug 30, 2016 01:03 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
coryc85
Jul 6, 2015 04:07 AM
