Sponsored by: CARiD
Testing Fuel injector
Old Dec 23, 2014 | 10:28 PM
83yotaman's Avatar
Just curious to know if you can test newly installed injectors for leaks. I hate to put everything back together and find a leak? thanks.
Old Dec 24, 2014 | 10:05 AM
83yotaman's Avatar
Old Dec 28, 2014 | 09:22 PM
slow-mo's Avatar
I'm not so sure on a Toyota as I had one with a carburetor, but on my Mazda EFI, the manual says to mount the fuel injectors in the rail, then mount the rail onto the intake plenum. This is of course all off the engine. From there, cycle the ignition on and off to check spray pattern. When the injectors are turned off, you can visually check to see if there are any leaks.
Doug4320
Mar 24, 2018 10:11 PM
raptor510
Feb 17, 2017 07:11 AM
RatOmeter
Oct 22, 2015 03:17 PM
pyramid
Jul 30, 2015 10:05 AM
HookahRoo
Jul 20, 2015 07:06 PM
