Sponsored by: CARiD
Spring-under conversion for no-lift crossover steer?
Old Dec 5, 2014 | 11:51 PM
moroza's Avatar
Suppose I wanted to convert my 81 to crossover steering, but didn't want to raise the ride height from stock. I understand that the major issue is having the pitman arm and upper tierod clear both springs, which is why it's invariably done with a front lift. What if instead I came up with two 4" lift springs, but mounted them under the axle (about 3" thick, plus 1" or so for the spring thickness) to cancel out the lift? That way, I keep my center of gravity low but still gain the normally required clearance for high-steer. Bumpstops would have to be lengthened because the next point of impact is the oilpan, and there'd be a shim game to play for proper driveline and caster angles, but it's still a lot less work than links and coil springs. Has anyone done this? Thoughts?
Old Dec 6, 2014 | 01:46 PM
muddpigg's Avatar
Haven't heard of going spring under on a mini. Most don't recommend shims for front.
Offroading lift springs are longer than stock to give flex. So requires moving spring hangars. Could look at removing a spring out of pack to lower lift and wheel spacers to give wider footprint in front and IFS rear axle or wheel spacers for rear.
Have heard the lifts like skyjacker that have stock length but more height are rough. I ran Downey rear lift springs they had no flex compared to longer Allpro's I'm running now.
Old Dec 6, 2014 | 01:58 PM
moroza's Avatar
That's another thing about spring under axle - it requires longer springs with more arch, and presumably flex better?
Old Dec 6, 2014 | 02:13 PM
muddpigg's Avatar
IDK, seen alot of LC and sami guys go to spring over. But longer springs do give better flex. Would be interesting to see.
justdifferentials
14
Jun 11, 2017 08:36 PM
runnermedic
13
Sep 21, 2015 05:20 PM
Kylenicoll33
Sep 17, 2015 08:40 AM
89hilux1
Sep 14, 2015 06:13 PM
128keaton
Sep 3, 2015 05:09 PM
