Sponsored by: CARiD
4wd not working
Old Jan 18, 2015 | 07:49 PM
Luke99tacoma's Avatar
4wd not working
So I was trying to go up a hill today... Just a grassy hill I wasn't even mudding and just tried to go into 4-Lo with the rear diff locker on and the front wheels just wouldn't turn... I'm not sure what happened we tried it several times and nothing... Only two wheel drive... Am I doing it wrong is there a different procedure I should do putting it into four wheel drive? All I did was just put the truck in neutral, shift the four wheel drive to 4lo and the pull first gear the whole way... I could feel the gears grinding a little when I was putting it in to four wheel drive so I know it was going somewhere I just don't know what to do... Any reply will help thanks
Old Jan 18, 2015 | 09:25 PM
dropzone's Avatar
Fossilized
Does your taco 99 taco have manual hubs and did you forget to lock them?
Saw it happen before
Old Jan 18, 2015 | 09:27 PM
Originally Posted by dropzone
Does your taco 99 taco have manual hubs and did you forget to lock them? Saw it happen before
not that I know of.. I'll take off the center caps tommorrow just to double check... I hope that's the problem
Old Jan 18, 2015 | 11:49 PM
wyoming9's Avatar
Red face
If it has center caps you don`t have manual hubs.
How often do you shift the transfer case into 4 wd??I shift mine every couple of weeks
The ADD actuator the VSV`s can all get stuck vacuum lines can start leaking better to know before you really need to use it.
electrical things can corrode wires can get damaged.
Old Jan 19, 2015 | 04:48 AM
Originally Posted by wyoming9
If it has center caps you don`t have manual hubs. How often do you shift the transfer case into 4 wd??I shift mine every couple of weeks The ADD actuator the VSV`s can all get stuck vacuum lines can start leaking better to know before you really need to use it. electrical things can corrode wires can get damaged.
would installing manual hubs fix that?
Old Jan 26, 2015 | 11:45 AM
and I know it's not electrical due to the locker engaging... The computer knows it's in 4x4 so it must just be the vacuum lines or hubs.. I just looked up a manual hub conversion and it's gonna be a butt load of money so I guess that leaves me with repairing the vacuum lines
Old Jan 26, 2015 | 01:24 PM
habanero's Avatar
No, it would only change what is happening at the wheel, not the diff.
Old Jan 26, 2015 | 01:31 PM
okay what do you think I should do
Old Jan 27, 2015 | 06:05 AM
habanero's Avatar
Just because the locker is engaging or the rear is working doesn't mean the front isn't having issues. As Wyoming9 said there's electrical and vacuum components. If you're sure the front isn't engaging start there.
I am assuming you don't have two busted cvs (and that you have cvs) and that the front driveshaft's intact. I don't know what the truck's history is or what any po might have done to it.
Old Jan 27, 2015 | 06:15 AM
Terrys87's Avatar
Not trying to be critical of you, but on my 01 Runner, there is a 4WD button on the transfer case shifter. Did you engage it? I knew a guy that was not happy with how his 00 Runner was acting. He was dis engaging the Over Drive thinking that activated the 4 wheel. Also I dont know the Tacomas if they are set up the same as Runners.
Old Feb 5, 2015 | 01:25 PM
nope not any buttons on mine fully mechanical tranny and transfer case thanks for the idea though
Just because the locker is engaging or the rear is working doesn't mean the front isn't having issues. As Wyoming9 said there's electrical and vacuum components. If you're sure the front isn't engaging start there. I am assuming you don't have two busted cvs (and that you have cvs) and that the front driveshaft's intact. I don't know what the truck's history is or what any po might have done to it.
me and my brother will try to trace all electrical stuff this weekend thanks
Old Feb 5, 2015 | 01:45 PM
wyoming9's Avatar
Red face
You never said if this is auto or manual??
Two very different systems !!
Then I sure would not want to look at the electrical end of this without the schematics your just going to get frustrated .
Now unless yours is wired different then my 2000 Just because the rear differential is locked does not mean that the ADD is engaged.
Then your truck could have some custom wiring additions.
One never knows the interesting things one might find.
Old Feb 10, 2015 | 05:34 PM
You never said if this is auto or manual?? Two very different systems !! Then I sure would not want to look at the electrical end of this without the schematics your just going to get frustrated . Now unless yours is wired different then my 2000 Just because the rear differential is locked does not mean that the ADD is engaged. Then your truck could have some custom wiring additions. One never knows the interesting things one might find.
okay what should I start with the ADD?
Old Feb 11, 2015 | 05:05 PM
thefishguy77's Avatar
Have you checked the fluid level in the tranny, tcase, and front diff? Is there fluid. How does it look how does smell?
ashersullivan88yota
Jan 18, 2022 05:37 PM
mskalmus
May 28, 2017 07:51 AM
Road Bull
Oct 10, 2015 04:55 PM
cyclist231
Jul 7, 2015 12:56 PM
Suprarossa
Jul 6, 2015 05:21 AM
