Sponsored by: CARiD
95 22re in an 83
Old Oct 17, 2014 | 08:25 AM
oilspot's Avatar
95 22re in an 83
I wanna pull the motor outta my 95, scrap the efi, and run a carb setup in my 83. Are there any things that get in the way of this swap ?
Old Oct 17, 2014 | 01:31 PM
thefishguy77's Avatar
It should be easier to go from efi to carb. Vs the other away around. Don't know a lot about the crab models but I would be willing to guess the throttle linkage is different and a few other things. I am sure it has been done a lot. You should check out the engine swap section and see what you find. If no luck there. Check out the 83 and older section. Good luck and do a lot of reading before you start.
Old Oct 17, 2014 | 07:10 PM
Terrys87's Avatar
The 85 and newer motor is different from the 84 and older. It will work. There will be the bracket that bolts to your valve cover for the linkage like thefishguy77 mentioned. I think you will need a 85 and newer intake manifold for the carburator. The 83 wont bolt up to it. There may be some other small details that I may have missed but I have seen it done and it works great.
The alternators are different so that it could be a different bracket. You will need to look into that as well. The brackets may just swap over from each other. As far as the motors on the older and newer generations, treat them as two completely different motors such as heads, blocks,ect... very few parts interchange.
Old Oct 18, 2014 | 01:55 AM
wyoming9's Avatar
Red face
The interesting part will be to figure out just what ECU to use with the 95 engine .
Most likely the easy thing to do would be to find the complete carburetor engine with wire harness and ECU to match your transmission.
Now if you have no need to meet emission laws it will be a little easier.
The thing is your going from the old style block to the newer block like was mentioned your intake and the timing cover parts are all different.
The best thing to do would be to have a copy of the Toyota EWD`s for what ever year parts you get.
No quite just swap in the engine and go.
Do your research !!
It would be much easier to just swap the complete engine and keep the EFI
you would just need to upgrade the fuel system for the fuel injected pressures.
Why do you want to scrap the EFI ???
JNapolitano
Nov 14, 2019 07:46 PM
Stull
Aug 28, 2015 05:53 AM
ia02
Aug 20, 2015 11:04 AM
PlayAwhile
Jul 20, 2015 11:36 AM
