Sponsored by: CARiD
Motor oil in clutch master cylinder
Old Dec 17, 2014 | 08:43 PM
Dale Johnston's Avatar
From: Strafford Missouri, right outside of Springfield
Exclamation Motor oil in clutch master cylinder
So I have a slow leak in my hydraulic clutch and today I ran out of fluid on a dirt road in a snowstorm. The only thing I had to put in the reservoir was 10W-40 motor oil. I know it calls for DOT 3 brake fluid, and under normal circumstances that's all i would have put in it. How much, if any, damage will the thicker fluid cause? Thanks for any advice!
Old Dec 17, 2014 | 09:06 PM
millball's Avatar
Might be Ok if you flush the system well with isopropyl alcohol ASAP and refill with Dot 3.
Petroleum is bad news for all brake rubber.
If you already had problems though, might as well figure on replacing slave, master, and flex hose. Still need to flush the lines with alky.
Old Dec 17, 2014 | 09:45 PM
Thanks MillBall. I will have to do it tomorrow, but i suspect you're right about replacing them. Im making a PickNPull run this weekend anyway.
Old Dec 17, 2014 | 11:26 PM
wyoming9's Avatar
Red face
You really don`t want to put used hydraulic parts on.
Then after all it is yours best of luck.
bigjstang
Jun 2, 2025 03:56 PM
mskalmus
May 28, 2017 07:51 AM
Sep 4, 2015 09:27 AM
cars-guy
Jul 11, 2015 07:51 PM
Coreyr384
Jul 10, 2015 11:13 AM
