Sponsored by: CARiD
Help injector wiring
Old Dec 15, 2014 | 01:21 PM
Claytouchstone's Avatar
12-15-2014 09:37 PM by Claytouchstone
Alright so I have a 22re and I'm not getting any gas, I have good pressure at the rail so then my mind went to electrical. After reading around I found out how it works and that's with a hot wire and then a pulsing ground to make the injectors work. When the key is off both wires are grounded and when I turn the key off I loose the ground and one becomes hot, well when I turn it over I'm not getting a pulsing ground so I thought that was my problem. So I just jumped a wire from my negative on my battery to the supposed to be ground wire and trying to crank and got nothing. Then just trying stuff out I jumped a wire from the positive on my battery to the already hot wire and it started to crank and ran.. What's going on??
Old Dec 15, 2014 | 01:27 PM
Injector wiring please help
I have looked into many threads and have not found my same problem so I need some advice. Alright so I have a 22re and I'm not getting any gas, I have good pressure at the rail so then my mind went to electrical. After reading around I found out how it works and that's with a hot wire and then a pulsing ground to make the injectors work. When the key is off both wires are grounded and when I turn the key off I loose the ground and one becomes hot, well when I turn it over I'm not getting a pulsing ground so I thought that was my problem. So I just jumped a wire from my negative on my battery to the supposed to be ground wire and trying to crank and got nothing. Then just trying stuff out I jumped a wire from the positive on my battery to the already hot wire and it started to crank and ran.. What's going on??
Edit Reply
Old Dec 15, 2014 | 01:47 PM
wyoming9's Avatar
Red face
Just what year engine are you working on?? Might help narrow things down a bit.
Or at least tell us what color wires you have on your injector connections.
If this is pre 89 The solenoid (injector ) resistor may be open.
Lets hope you didn`t do any damage
Old Dec 15, 2014 | 01:56 PM
The motor is a 22r converted to fuel injection, and I believe the wires are white and red and white
Old Dec 15, 2014 | 02:26 PM
wyoming9's Avatar
Red face
You have a mess!!
Get the Toyota EWD`s for the year of your truck and the year the engine parts came from.
This is some thing that needs done in person!!
Did you do this work Or did you buy the truck like this??
At any time did it run at all like it should??
Just what ecu are you using??
Old Dec 15, 2014 | 02:39 PM
RAD4Runner's Avatar
Originally Posted by Claytouchstone
... I jumped a wire from the positive on my battery to the already hot wire and it started to crank and ran.. What's going on??
Originally Posted by wyoming9
If this is pre 89 The solenoid (injector ) resistor may be open. Lets hope you didn`t do any damage
Exactly.
O.P., Before jumping anything, shorting things, out, etc, check the schematic.
Old Dec 15, 2014 | 02:41 PM
Alright so I bout the truck and it is a 90 model. Well I flung a rod in it and the only motor I could find was a 22r so all i did was convert it to 22re with all the parts that were on it originally and yes it runs great when it does run. And the ecu that is in it I guess is a 90
Old Dec 15, 2014 | 02:44 PM
rworegon's Avatar
O.P. merged your other thread into this thread.
Old Dec 17, 2014 | 12:00 AM
wyoming9's Avatar
Red face
Post a few threads get some suggestions then don`t reply back as to what you think interesting.
Doug4320
Mar 24, 2018 10:11 PM
raptor510
Feb 17, 2017 07:11 AM
steve miller
Oct 10, 2015 01:40 AM
sanctfy
All Other Toyota Swaps
Sep 15, 2015 02:52 PM
Tacoma1313
Aug 17, 2015 05:44 PM
