- Oil and tranny leak ?
- Front Axle popped out of Differential
- Trouble with locks
- 1987 4 runner suspension problem
- Engine Upgrade
- Oil in Radiator
- 90 4 runner.. HELP PLEASE!!!
- Misfire, researched, need help!!!!
- 2002 4-runner idle speed too low
- Fuel Filter Replacement
- Synthetic Oils
- engine question?
- Who can install a roll bar on a 1980 pickup?
- N00b Build...where to begin
- Putting bumper on
- another tire size question
- Auto to 150 5speed swap need wiring help
- Rear Locking Differentials on 98 Tacoma
- Quick Locking Hub Question (86' 4Runner)
- fuel return line
- Toyotas with carburetors
- 91 P/U LOUD creaking/popping in front when turning, CAN'T FIGURE OUT!!
- Battery cable broken... fix??
- idle at 1500 rpm warmed up
- Newbie - 1986 Pickup Oil Leak
- 93 toyota idle problems
- help! fuel problem-22RE
- Newbie looking for part help
- 97 tacoma transmission wires
- Dies after a second
- Rear U-joint going out?
- Gear oil coming out diff breather
- window problems
- Truck wouldn't start in a precarious spot!
- 3rd gen pickup running 33's with little to no lift
- 3.0 swap to 22r
- Convert Drum brakes to Disk brakes??????
- just bought an 86 have a few questions
- need help with 4x4
- Newbie needs help-leveling truck?
- overheating.
- Will this tranny work in my truck?
- 90 Yota 4x4 5 Speed Tranny Info
- solid front axle bracket removal
- E-Locker not locking any more
- Driveshaft Grease
- Help removing rear fender
- Newbie advice..... links or springs
- Newbie wants more power for 2.7 L 4 banger
- New lift.... new questions....
- coils to springs
- Timing nightmare.
- Rust Stains on carpet
- Anyone heard of Rock Products?
- Newbie cone washer removal
- 1980 solid front axle vented rotor conversion help
- Newbie needs to know how to remove solid front axle diff?
- Do you know who owns this 4Runner?
- Bumpers that fit with a body lift?
- Clutch installation!!!
- Power steering pump replacement questions
- chrome bumper paint issue
- Gas Tank LIFT questions please help...
- 1991 4Runner Power Steering Noises
- 22RE Sensor
- Blowing Oil Out of the Dipstick
- hard to shift into 1st gear
- Best grounding spot in engine bay when jumping gen 3 4runner
- Auto Part Store Opinions
- Newbie tires rubbing when turning
- SAS on a 98 Tacoma
- rear brake line failure
- cold start up issue
- Steering wheel compatibility?
- Reserve Tank amount?
- Shifting into 4WD
- AC Help
- Brakes What to Do?
- Swapping A340H for A340F
- What Weber carb will replace a stock '85 carb?
- need ideas on whats wron with my 86 4runner!
- Hey boys...help a girlie out...rear drive shaft help!
- Is the 4 cylinder really this gutless? 3rd Post (they keep disapearing)
- 'RR Diff Lock' good as any other rear locker?
- this is what my muffler looks like...
- Newbie please help me identify these add ons
- 85 Front axle building on a budget?
- Battery Acid Rust Problem
- Secong thoughts on LT. Maybe SAS?
- 1988 4runner 22RE engine swap
- what is the actual name of my tranny?
- 1999 4Runner Build up thread
- 3vze injector questions
- Driveshafts
- How long does it take do do a timing chain?
- testing the ignitor?
- Hey Guys! I'm new here
- gears rubbing-carrier damaged?
- i think I made a boo boo: EFI Vacuum lines?
- 3vze fuel problems
- ac/dc?--distributor current
- Oil Dipstick? runs weird when removed
- 4x4 questions..
- my 4runner smells!
- Need a new 22RE
- Whats my All Trac worth $$
- '02 4runner lift help
- What Makes pre-1995 Toyotas Good Offroaders?
- 94 22re auto tran donor to a 82 yota pickup stan. 4 srd
- Newbie T-Case doubler question
- Arb front bmper and ifs question
- Motor swap or regearing?
- help properly adjusting (throttle/kickdown/throttlebody/tps/egr)
- quick relay question
- 91 4runner 4x4 v6 manual
- Easy Answers
- timing tentioner and injectors
- 92 4runner has no power and shifts way too early
- Super stock 3.0
- Clunk when you come to a stop and take the brake off
- Sway BARs on IFS
- Transmission slip
- Timing cover help
- need help to find performance parts for my 94 4runner sr5
- Introduce myself and bad noise
- Grapevine Hwy 5
- headers
- burnt valve,bad seat?
- Newb locker questions
- Rough idle/poor acceleration
- bad noise coming from front end in cant find
- Newbie engnbldr rebuild kit questions
- 22RE starting stumble
- How do leaf springs provide lift?
- 88 V6 cranks but won't start!
- full size chev engine swap questions
- Flipped ball joint boots
- help a guy out! engine swap questions
- Smitty Built bumpers/rollbars
- rear spring ?
- Fuel Capacity??
- axles?
- 4 inch bracket lift with 2 inch body lift and 35s on a 2nd gen 4runner?
- SC14/12 on a 22re
- 1985 4x4 straight axle steering?
- 2.4 L or 2.7 L 1996 Tacoma
- Undercoating Bumpers and running boards
- new guy with questions about his 79 4x4
- tacoma wheels question....help!
- lift question for 84 4runner
- front 3rd, 54 mm socket??
- trail(TUBE) doors or half doors?
- Antenna HELP
- Are my shocks correct?
- Newbie with 2.5" daysta lift
- First lift
- crooked drain plug?
- 1stgen 4Runner Sag 89-95 Springs?
- 4runner wandering at higher speeds
- What is this noise!!! after Zuk spring swap
- cheap truck challenge
- 1st/2nd gen bumpers
- 4runner 4wd
- wont turn over after new timing chain
- 93 4runner-what lift, brakes, and more?
- 3.0 noise
- Buying a '99 4Runner - SR5 or SR5 Highlander? Gear quesiton too - Can you help?
- what do you think: 4Runner lift recommendations
- Start/Run Issue
- 2003 4Runner: Misc Questions
- New To Yotatech
- prerunner vs. rock crawler 1990 pickup
- wheel swap
- Truck is overheating and loud noises from radiator
- Thrust Bearings in Oil Pan please help
- Help me find the right machine shop.
- *New* Toyota pickup NEWB repair question
- Brake Booster Hook up
- changing clutch on a 4x4 tacoma
- Vacuum leak?
- 97 4runner Folding Seats
- 84 yota wont idle right
- 99 4runner towing question
- fuel leak
- Newbie needs a light bar
- Two Fuel Pumps ???
- Gage's not working?
- need opinion on ifs lift
- What year trucks/4runners have compatible 22re's?
- Transmission Noise
- 22R jerks during constant speed.
- Help a newbie ignition timing confused
- What gas 87 91 or 93
- Hot Ignitions
- 1994 4runner rear coil sizing?
- Dune comfort
- Ball Joint replacement options, labor cost?
- Locks not working? Try lubricating them
- lowering a 4runner
- shifter problems after body lift
- 22re wont stay running
- new to me 81 4x4, few questions.
- Manual Transmission bolt HOLE stripped
- wrist pin question ?
- 22re power lag
- 4 in downey/rancho lift
- anyone know where i can get some diamond plating?
- HELP! Drained transmission
- first ball joint replacement (dakota)
- Need opinions on IFS Front axle locker.
- Where can I get a factory roll bar?
- 2wd to 4x4
- Identifiers of e-locker equipped
- help with 86 4x4 auto trans
- toyota transfer case stuck in 4 High
- Whats with my hubs??
- Removing Welded Sliders - Looking for Best Approach
- 1983 Yota Engine Swap
- What grease to use?
- leaf springs vs coil springs?
- Half shaft from cardone?
- Where's Best place for brake lines?
- idel problem
- questions on how to improve my 85 for cheap
- How do you replace the front turn signal bulbs on a 3rd gen pickup
- 93 4wd 3.0L engine removal
- brake indicator light won't turn off means low on brake fluid
- 1989 4runner dumbo mirrors!!
- High steer kit
- Help me pick a muffler
- rear coil lift
- Towing Help please.
- 85' pinion help..
- 83-84 Yota Pickup 2WD 22R Engine Ticking
- Looking for offroad advice
- advice on removing some lift on 97 Tacoma
- FSM for '87 4Runner
- swap in a TRD axle on my non TRD truck?
- Driving in 4 Wheel Drive
- Air Conditioning HELP!
- ifs body lift
- regular cab swapping to extended
- do i need a coil spring compressor
- Rim and Backspacing question
- 5VZFE Valve Cover Gaskets
- Alternator issue...i think
- 1991 toyota pickup v6 4x4
- Tune UP 2000 Runner V6
- Removing my front lift?
