Sponsored by: CARiD
hard to shift into 1st gear
Old May 2, 2010 | 08:33 PM
tcop's Avatar
So I have an 85 efi 4x4.
I drive it around town and on the freeway.
It has 255k on the trans. It shift good through all gears doesnt
pop out of gear at all. The problem is went I come to a stoplight.
I make a complete stop. Tranny is in neutral. I go to put it in 1st and
it seems like it doesnt want to go. I shift to 2nd then back to 1st and it
goes in.
Can anyone answer my why and do I have a problem.
thank
Tcop
Old May 2, 2010 | 08:59 PM
whutface's Avatar
Mine never wants to go into first or reverse unless im at a complete stop. and than sometimes reverse still wants to give me trouble.. other than that its great
Old May 2, 2010 | 10:04 PM
toy-yota7's Avatar
syncros are probably going out, trany will still work. just hard to get into gear unless at just the right rpm and mph.
Old May 3, 2010 | 02:25 AM
Aenema's Avatar
Mine has the exact same problem, i just learned to live with it.
Old May 3, 2010 | 06:29 AM
myyota's Avatar
Try replacing the shifter seat and bushing, that should help the shifting problem your having. Marlin Crawler sells these parts and there better quality than oem.
Old May 29, 2011 | 01:10 AM
rattlers's Avatar
sorry to bring back, mine is doing the same thing, did you find out what the problem was ?
Old May 29, 2011 | 07:49 AM
SoCal4Running's Avatar
Most of the higher milage trans do this. Going to 2nd then 1st always works for me.
Possible bandaids other than major trans repairs include good synthetic trans flux, making sure your clutch system is performing properly and fully disengaging and changing the seat bushing.
Old May 29, 2011 | 07:53 AM
Jory121's Avatar
My 87does this as well... Wonder if its a problem with high mileage tranys?
Old May 29, 2011 | 08:02 AM
toyota4x4907's Avatar
I seem to remember my '93 having this problem starting around 120K miles.
My '88 4runner (206K miles) I had to do the 2nd gear shift to get it into 1st gear about 50% of the time.
Now, my '95 4runner (147K miles) has been the worst. Has done it since I bought it at 126K miles. Pretty much refuses to go into 1st or reverse without 2nd first.
Its just second nature to shift it into 2nd then 1st/reverse for me now, on any manual trans. Dont think its strictly high mileage issue.
Old May 29, 2011 | 11:19 AM
Moonfish's Avatar
Have you tried double clutching? My 90 Pu only won't go into first when the fast idle is kicking in. When it idles normal, no problems most of the time.
Old Jun 7, 2011 | 09:33 PM
fork's Avatar
double clutching in my 89 (transmission from an 87) wont do it. 2nd then to 1st sort of does, but sometimes it plain refuses and i have to beat it into first gear. reverse grinds but i just hit it in fast and it goes. i always double clutch and it has no effect for me. also, the bushings are brand new from toyota installed this year. im starting to get worried though that one day ill get locked out of first entirely. my 86 does this also. i make it a habit to get down into first gear while im rolling.
smthwsn357
May 1, 2024 07:28 AM
mskalmus
May 28, 2017 07:51 AM
Tykiller1994
Aug 10, 2015 07:49 PM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
Jnkml
Jul 6, 2015 01:20 PM
